Results 1 to 8 of 8
Thread: Engine running Hella rich Lots of soot
    Junior Member Nazeradi's Avatar
    Nov 2014
    Yusuf
    Connecticut
    New Haven
    USA
    Default Engine running Hella rich Lots of soot
    Car: AE86 SR5 (4AGE Converted)
    Engine : 4AGE 16v out of an 89 MR2
    Problem: I swapped out a 4AC for a 16V 4AGE out of a MR2. All stock except the intake and the FPR, Runs strong except that it dumps fuel like crazy. The car reeks of gasoline, sooty spark plugs, sooty exhaust, hard starting when warm, not to mention horrible gas mileage. Now i do have a walbro fuel pump running in line, not sure what the specs are but i kno that its dumping fuel into the engine. So do I change the pump, or the injectors? Or something else? Any suggestions?
    Sometimes i'll get somewhere, run a quick errand and the car won't start this usually happens when it's warm. I'll play with the FPR, and she eventually fires up. This probaby stems from the rich running engine issue but im not sure, what does it sound like to you guys.
    I'd start by measuring what psi your fuel pressure is. If it is too high your car will run really rich.
    A common cause of high pressure is if the car has been sitting for a while the return line can block, blowing it out with compressed air sometimes frees it up.
    depending on the size/ flow of the walbro it could be to much for the stock pressure regulator to handle.
    start by checking those and let us know how you go. Faulty air flow meters or map sensors can also cause the same problems
    Nov 2014
    Yusuf
    Connecticut
    New Haven
    USA
    Thanks for the reply. Im gonna order a fuel pressure gauge. I'll install it and get the specs for the engine. I have a aftermarket adjustable regulator. Im a truck driver so i probably won't be home to fiddle around with it untill this weekend.
    Another problem I have, my crank pulley pretty much fell apart and the alternator belt slipped off so now imma need a new battery, pulley, and belt. I pretty much have a handle on that.
    Do you know how the engine ran in the mr2 ?
    Nov 2014
    Yusuf
    Connecticut
    New Haven
    USA
    I can't really say. It had a blown headgasket but it was rebuilt from that. Besides the fuel issue it runs well.
    Another thought is it could have gze injectors in it, what colour are they?
    Nov 2014
    Yusuf
    Connecticut
    New Haven
    USA
    Green at the connector i think. Its night time here in the states. Or maybe im going colorblind @__@... Lol Had to use a flashlight to look
    Nov 2014
    Yusuf
    Connecticut
    New Haven
    USA
    I may be wrong i need daylight to know for sure
  1. 4age running really rich, not sure what to do!
    By Sprinter Freak in forum Technical - Questions
    Last Post: 12th February 2012, 06:58 PM
  2. Running rich?
    By Ham86 in forum Technical - Questions
    Last Post: 17th March 2011, 07:22 PM
  3. Running rich
    By RolandGTV85 in forum Technical - Questions
    Last Post: 24th April 2009, 11:10 AM
  4. Running Rich
    By grape_moosha in forum Technical - Questions
    Last Post: 29th January 2007, 11:28 AM
  5. running rich
    By Maxhag in forum Technical - Questions
    Last Post: 1st June 2006, 06:52 PM
