Results 1 to 2 of 2
Thread: haltech e8+1nz COPs+ra10 ? tacho
    Jun 2011
    bazz
    nsw
    sydney
    Default haltech e8+1nz COPs+ra10 ? tacho
    finishing wiring of my 86
    full zenki body looms
    have wired in the haltech with the ra10, just want to know what people have used to make the original tacho work?
    i hear people use the msd 8910 tacho adaptor, will this work with the ra10 and the COPs
    Senior Member Dylan's Avatar
    Dylan
    If there is a tacho output setting in the Haltech you can use this with a relay to create a tacho signal for the original cluster. You just need to connect pin 86 to the ECU output and the cluster, pin 85 will go to 12V IGN. The way it works is the coil in the relay mimics the signal created by the original coil, just take the case off and bend the contacts so it's not noisy.
  1. Aftermarket ECU with Inbuilt Igintion drivers - 1NZ/1ZZ COPS ?????
    By Futo_gt86 in forum Technical - Questions
    Last Post: 10th August 2014, 08:31 PM
  2. Haltech E8 with flying loom
    By wideslider in forum Car Parts For Sale
    Last Post: 7th January 2011, 01:14 PM
  3. haltech e8 + coils
    By Rian in forum Car Parts For Sale
    Last Post: 16th September 2010, 04:31 PM
  4. haltech e8
    By fatke in forum Car Parts For Sale
    Last Post: 13th August 2009, 09:06 PM
  5. Haltech E8 - Just read if u know about ECU's
    By sundee in forum Technical - Questions
    Last Post: 5th March 2009, 02:17 PM
