Results 1 to 3 of 3
Thread: spare/temp burrow t50
    Jan 2010
    Mahir
    Western
    Default spare/temp borrow t50
    Hey guys,
    Well couple weeks back i thought id take my car out for a small trip to grab dinner with the misses. Now on the way back the unexpected - when trying to shift from 3rd to 4th heard a crunch and it struggled to go into gear - infact it didnt go into 4th at all.. i tried shifting back into third but i had to pull over - oncde car rolled to a stop it stalle .. now it won't start without the clutch being pushed in..
    While the car is not running, stick is in neutral position - i can push it around, no issues. i pop it into first - and it locks up cant push it .. right. but i can't start it no matter what gear the selector positioned in - i need the clutch pushed in to be able to start it - and as i release the clutch it stalls..
    So conclusion (also an assumption) my box is screwed? since i had driven the car over a dozen times for 10-30 min drives at times and never were there signs of anything so im kind of shocked...
    Moral of the story - i would like to know if anyone has a spare t50 lying around that i could perhaps burrow to see if it is my box or not ?
    Feel free to add thoughts but i'm thinking copying the first 6 lines to technical thread..
    Yes something is broken in there, probably a selector fork or maybe a gear itself is causing the synchro ring to lock on. Unless you are building the box yourself it's easiest for a new one
    Jan 2010
    Mahir
    Western
    Cheers for the advice
  1. [NSW]3 x Omori gauges Oil temp, Oil press, Water temp
    By anastasios in forum Car Parts For Sale
    Last Post: 25th January 2015, 03:22 AM
  2. Gauges wanted - Oil pres, oil temp & water temp
    By sirsprinter in forum Cars or Parts Wanted
    Last Post: 30th October 2014, 12:04 PM
  3. (VIC) AE7111 FOR SALE! HAD THE WORKS DONE!+spare motor+2 spare front ends
    By Maciek in forum Cars for Sale (Toyota Only)
    Last Post: 9th January 2013, 07:22 PM
  4. Replies: 6
    Last Post: 7th November 2007, 05:10 PM
