Results 11 to 20 of 24
Thread: TRD shock question?
  1. #11
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    trd yellows are good,
    i got brand new kyb agx st185's sitting in the box's in my room waiting to be used just lazy and yellows are still going strong so why not keep them till they get saggy
  2. #12
    Senior Member GOODY's Avatar
    Logan
    Do they have the part number 365077?? I can pick up a pair of them fairly cheap but don't know if I should just go ahead and get some trd yellow for a bit more.
    Is there a whole lot of difference between the two?
  3. #13
    Dave
    Western Suburbs
    na was different dont remember off the top of my head but they sound liek 204/205 numbers
  4. #14
    Logan
    Ahh ok, I was under the impression they were for kyb agx st185's??
  5. #15
    Nick
    Erindale
    The part number for the KYB AGX ST185's is 765015 if that helps. I will be getting these for my conversion.
  6. #16
    Logan
    Ahh ok, so does anyone know off the top of their head what shock has the part number 365077? BecauseI'm a bit confused..
  7. #17
    Moderator Frak's Avatar
    Jamie
    I'd only recommend the 60mm cut and no spacer on a car that sees little road use,
    for road use/odd track outing, I'd recommend the 40mm cut with a 20mm spacer, will give you 20mm more droop. With the 60mm cut, you have to run the car low, which considering how the police are now is probably not the best thing.
    Hachiroku since 1994
  8. #18
    Logan
    Ahh ok thanks mate that explains it a bit better for me. Are there spacers readily available on here? Or do most people just make up there own?
  9. #19
    Jamie
    Most guys make their own, you can buy them in Japan, so id someone's importing stuff they might be able to get for you. Or if you know someone with a lathe they can knock them up in no time
  10. #20
    Logan
    Might sound a bit dumb but would I just be able to use some steel piping cut to the appropriate length?
  1. Trd yellow front shock inserts
    By slidernt in forum Car Parts For Sale
    Last Post: 19th December 2012, 07:07 PM
  2. BC coilover shock question
    By Rice86 in forum Technical - Questions
    Last Post: 18th November 2012, 10:02 PM
  3. Shock info question
    By sdrawkcab in forum Technical - Questions
    Last Post: 24th May 2010, 08:04 AM
  4. ae101 shock question
    By kes16v in forum General Topics (No Technical Questions)
    Last Post: 8th February 2008, 11:02 PM
  5. TRD shock part number
    By Sparkle86 in forum Technical - Questions
    Last Post: 17th January 2008, 01:45 PM
