Glenn, is that the F series axle that I should have grabbed when I picked up the two F series spooled - T series diffs?
i have a pair of t series ra23 axles 150
and 1 ra40 series t axles with bango and drum brakes 250
also have 1 F series axle 100 anf heaps of 4age parts
a lot of altezza 3sge parts as well ,some are red top beams mainly engine mounts, harmonic balancers. p/steering pumps and 1 gear box xmember
2 exhaust headers std altezza 1s 75 each
alternators 100 each plus numerous parts will get around to put up some pics
ti valves to suit altezza 300 a set of 16came out of low klm motors
rods and pistons 11,5 to 1 $200 a set
valley covers suit 4age
rocker covers suit 4agze
early and late covers
plus some water pumps etc ,
all parts are in melb ,wil send at buyers expense
now with pics
you can buy it as a spare if you like
also have the t series disc brake calipers as well
Do you have bolts that connect the alternator to the bracket, or any of the bell housing to block bolts for a beams 3sge?
no sorry
That gearbox sandwich plate ~ is that from a 4AC ae71? (rhs 1st pic and the one in last pic) cheers
all of them are from 4age
Hey mate I PM'd you about Disk Brakes
PM sent
