Results 1 to 2 of 2
Thread: [NSW] 84 Panda Levin GTV AE86 3Dr - 20v Blacktop
    Junior Member collins's Avatar
    Grasmere
    Default [NSW] 84 Panda Levin GTV AE86 3Dr - 20v Blacktop
    Hi guys.
    Car:
    -1984 Panda Levin GTV AE86 3Dr
    Engine/Driveline:
    -4A-GE 20v Blacktop
    -Toda Pistons
    -Tomei Rods
    -Tomei Main bearing ladder caps
    -ACL bearings
    -TRD head gasket
    -GReddy Oil Cooler/filter relocation kit
    -Nobby Booth Carbon fiber intake
    -Apexi pod filter
    -1NZ coilpacks
    -Standard head and cams with VVT
    -Haltech PS1000 ECU
    -Jasma Extractors
    -Apexi Cat
    -2"1/4 from cat back (under diff)
    -Combination of Sam-q, 16v and custom RWD conversion parts
    -Motor is ~10,000kms old
    -Made 97kw on JEM dyno
    -Jap T50 gearbox
    -T3 Short Shifter kit
    -4.3:1 Crown wheel and pinion
    -TRD LSD (2 way i think)
    -Zenki Disc brake rear end
    Suspension/steering/Brakes:
    -Front Struts converted to coilovers with AJPS kit, 6Kg springs, TRD blue 5 way adjustable, Cusco tops
    -TRD Blue rear shocks
    -TRD Blue rear Springs (6kg)
    -AJPS tierod ends
    -AJPS RCAs
    -AJPS lock spacers
    -GTV/P/steer arms
    -Corona lower contol arms
    -Selbys front adj. 24mm swaybar
    -Selbys rear adj. 20mm swaybar
    -Jap Disc brakes front and rear (could probably do with new pads and rotors soon but not urgent)
    Interior:
    -Very clean original Black/Grey/Light bluish color interior
    -Pioneer (i think) Head unit (has bluetooth and hands free)
    -2 4" speakers up front.
    -Oil Pressure, Oil Temp, Coolant Temp guages (some ebay brand seem decent quality though)
    -Factory GTV seats with built in rib cage adjusters.
    -Nardi Steering wheel.
    -Fire extinguisher mounted behind center console.
    Exterior:
    -Resprayed in Panda GT-Apex style. (was red once upon a time)
    -Factory Boot spoiler
    -Kouki Front lip.
    -Kouki Front bumper
    -Kouki Head lights (HIDs fitted)
    -Kouki Parker/indicators
    -Kouki Rear bumper
    Wheels/Tyres:
    -SSR mesh 15x7
    -4x Good RE001 Potenzas
    Spare Parts:
    -T50 gear box
    -Bilstien front shocks
    -4.5:1 TRD LSD diff center
    -What ever else i can find in my garage that i cant be bothered selling separately basically
    -Brand new s13 rear rotor conversion kit
    Bad Points:
    -Drivers outside door handle doesn't work (just needs a new handle)
    -Needs a new battery
    -Rego expired and will need blue slip (have a stock air box to go with the car to help with this)
    -Was in a pretty decent accident mostly on the passengers side front a few years ago. Structural damage was repaired in workshop cosmetics i did my self but it drives straight, handles and looks great.
    Note: most of what i have listed was just from memory as im not near the car at the time of making this sale so i cant check somethings and its been a while since i have driven it. i may have forgotten a few bits and pieces or gotten the brand names or specs abit off but should be pretty much spot on, i apologize in advance if i have done so with anything.
ID:	34477   Click image for larger version.
Name:	20v in close OS lw.jpg
ID:	34478   Click image for larger version.
ID:	34479   Click image for larger version.
ID:	34480   Click image for larger version.
ID:	34482   Click image for larger version.
ID:	34483   Click image for larger version.
    Grasmere
    SOLD!
  1. AE86 JDM GTV KOUKI TRUENO 3dr Hatch *** COMPLIED***
    By 44GTE in forum Cars for Sale (Toyota Only)
    Last Post: 1st February 2015, 09:41 PM
  2. AE86 GTV Trueno 3DR Hatch
    Last Post: 16th April 2012, 12:18 PM
  3. AE86 Trueno GTV 20V Blacktop
    By jcae86 in forum Cars for Sale (Toyota Only)
    Last Post: 19th August 2008, 12:21 AM
Tags for this Thread
