Yes very normal! Nothing to worry about. Make sure you fill it up to the correct level ONCE it's fitted in the car with the tailshaft in, as even when it is mounted up in the car horizontally, it will leak oil (read pour out) from the same place if the tailshaft isn't in.
Cheers, Will.
