Results 1 to 3 of 3
Thread: 1jz injectors into 20v BT
    Oct 2010
    Josh
    sa
    golden grove
    Default 1jz injectors into 20v BT
    I know there's a few of these threads already but most seem old and have mixed answers.
    ive fitted the injectors already , they fit perfect and plugs were standard. My question is more related to OHM's: I was originally told straight swap , but now I'm reading some are low, some are high.
    Just looking for peace of mind
    thanks
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Using a multimeter across the pins measure the resistance. If the measurement is very close to being the same(between the black top and 1jz) then you are good to go.
    For example, 4agze I had originally were 3.5 vs. 7mgte which I fitted being 3.0-3.1 ohm.
    May I ask why you are changing /increasing the flow rate? Boost?
    Also, what ecu are you using?
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Oct 2010
    Josh
    sa
    golden grove
    I've gone e85 for engineering/power. Car had an adaptronic 420d installed at the same time and is being tuned in Tyes day. So being a long weekend I can't really get to the car before then anyway to test with a multimeter
  1. 1jz injectors, slave cyl, clutch
    By Brendo in forum Car Parts For Sale
    Last Post: 1st November 2011, 12:48 PM
  2. bt 4age injectors, rando shit
    By ca18ae71 in forum Car Parts For Sale
    Last Post: 20th December 2010, 12:36 PM
  3. 1jz injectors upgrade for 20v
    By skin in forum Car Parts For Sale
    Last Post: 22nd November 2010, 12:30 PM
  4. [BNE] 380cc 1JZ Side Feed Injectors - Suit 20V 4AGE
    By Oly AE86 in forum Car Parts For Sale
    Last Post: 6th October 2010, 07:39 PM
  5. 1JZ SARD 600cc Injectors
    By James86 in forum Car Parts For Sale
    Last Post: 25th March 2010, 11:20 PM
