Results 1 to 7 of 7
Thread: removing 4a-c
    Timmy D
    North
    Default removing 4a-c
    Hey guys
    about to rip out a 4a-c from a ae71, quick question can i leave the gear box attached and remove both in one shot? or is it better to split them while still in the car?
    JJ
    Scammer, DO NOT BUY FROM ME!
    should be able to get motor and box out without to many problems.
    i guess it depends if u need to take the box out or not, if you have to take it out then yeh take em out together, if not it would be just easier to leave the box in there and lift the engine straight out
    HAHAH I LOVE BOOST LOOSING!!
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Definitely leave the box attached, done it so many times and its the way to go.
    There is 1 bolt on the bellhousing which is a real prick to get at whilst its all still in car, so its much easier just to pull the whole lot out in one go.
    You'll just need to put you crane chain/strap on a pretty crazy angle so that it comes out without getting stuck.
    Dave
    oh man, 4-ac is the greatest engine to remove (2nd only to 4kc)
    there is SSOOOOOO much room in the engine bay, i think me and my mate had a 4ac out in like 45mins.
    Take the gbox out with the engine, those bell housing bolts are a pain in the butt to undo. just becareful as you will drop the oil out of your gbox though (unless you have a plug of some kind). ive thought about leaving the front half of the tailshaft in and sorta attaching it somehow, that might work also.
    4ac/4age are so light that it doesnt really matter where you put the crane, you can monouver them around real easy once they are airborne. just put it somewhere in the middle of the engine, wrap some rope/chain around the manifolds and it will work out good.
    - Blaise Pascal
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    setting the car up so the back is way higher than the front too makes things easier.
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    leave the box attached for sure its way easier
    ~KEEP DRIFTING FUN~
    Timmy D
    North
    box stays on then!
    i like the idea of having the rear really high i will give that a go aswell.
    cheers dudes
    JJ
  1. 4a-geu ecu pinout same as ae82 4a-ge?
    Last Post: 25th November 2009, 05:21 PM
  2. FS: Ae92 4a-gze 650$ or swap with fwd 4a-g
    By Mickey H in forum Car Parts For Sale
    Last Post: 26th June 2009, 07:16 PM
  3. removing old bushes
    By loc33e in forum Technical - Questions
    Last Post: 7th February 2008, 06:45 AM
  4. Unifilter Air filers, 4A-C Carb on 4A-GE manifold
    By asher in forum Car Parts For Sale
    Last Post: 15th June 2007, 08:16 AM
  5. 4A-GE head onto a 4A-C Block??!?
    By ironmonkey in forum Technical - Questions
    Last Post: 10th April 2007, 08:47 PM
