Layed down a thick coat of body deadener to the floor, it used to be so noisy
Got the scrubning brush out & cleaned all the dust out, also repaired the rust hole in the wheel well & filled the hole where a roll cage used to bolt into
still has the factory deadener & running full interior + carpets
Hopefully it quiets it down a bit whilst driving
Could barely hear the radio before!
Planning on using dynamat on the doors too once its all together again
Started to put the cooling system back in
It originally had a remote thermostat setup so im keeping that style & bought all new hoses & clamps
tridon high flow thermostat to replace the old gunked up one in there also
I also changed the top water outlet to the one facing the radiator rather than the one facing upwards (refer to pic) of course the rear piece was seized on so that took a few hits to break free
still need to paint it all up
The rear housing of the block im changing to the one on the right, more compact - even though the left (4agze mr2) one fit it was mighty close to the firewall
all new sensors on the way also
lots of goodies on the way big & small, should be here anyday now![]()
