Page 7 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 61 to 70 of 138
Thread: Harry's AE86 Build
  1. #61
    Noooob
    Put a block of wood in the calliper and hit it with compressed air where the brake line goes. Watch your fingers cos it'll shoot out
  2. #62
    Aug 2014
    Harry
    South Australia
    Barossa
    Thanks for the advice, i'll give it a go
  3. #63
    Aug 2014
    Harry
    South Australia
    Barossa
    Mounted up the front lip, with a bit of a minor mod it fits, all bolted on underneath so it wont be seen
    Looks factory!
    rear pods arrived & painted black
    Ball joints & tie rod ends arrived too
    just need to get a lock spacer & the steering side of things complete
    started doing some porting of the head too
    Nothing crazy just cleaning up some of the castings
  4. #64
    Aug 2014
    Harry
    South Australia
    Barossa
    Lots to update on
    When i changed out the tail lights from ADM's to whitelines i noticed there was alot of silicone & gunk sealing the tail lights in, didnt think much of it & the time
    Decided to take the tail lights out & scrape down the excessive amount of goo
    What did i find? Rust of course
    Only surface on the passenger side but still sucks, also it hasnt been painted properly either
    Looks like the tail lights been masked up :/
    Since i owned the car ive always had the thought in the back of my mind of the bubbling paint near the fuel lid on the arch
    Really didnt want to touch it since the bodys pretty straight but i bit the bullet & grinded it away
    Discovered a bit more rust, worse then i first thought
    I was going to cut it out & weld another piece in but there it is it wouldn't be simple
    Used some rust converter & a while later i applied a bit of glass fibre filler
    Waiting for it to cure for a while then i'll tackle it
    The bays getting very close to being done now
    I've combined all the lines & smoothed them out by hand
    Painstakingly slow process but it really makes the difference
    Last parts of the bottom end arrived
    Forged rods with arp bolts - works out there different then the standard one's so i'll have to sell the others (bit of a pain)
    Arp main studs
    Also MRP ladder reinforcement caps - was originally going to use tomei's but read good things about these
    Assembly started! Took my time with at all & made sure everything went in perfectly & how it should
    Yet to be torqued to spec
    Thought whilst i was at it might as well assemble the bolt on's too, painted the bolt heads too so it matches up nicely
    Mmmm shinyy
    It works out the ACL pistons i bought were bigports - i have a smallport block
    At first i couldnt figure out why the rods were so lose on the piston, then i did some reading & found out that bigport pistons have a 18mm wrist pin & smallports 20mm
    Woops!
    Luckily the forged rods were smallport sized (20mm - thank god)
    Im gonna use the oem smallport pistons now, there in really good shape anyways
    found out that becauase of the oil squirters on the block (7 rib) the piston has a slight cut out to allow space when its at bottom dead centre - never knew that
    Bit of a shame i couldnt use the new ones though
    thought it was strange that the 'bigports' dont have a groove for the circlip on each side of the piston too
    Getting the old rods of the pistons was a challenge in itself! Finally fitted up!
    The ACL pistons came with new rings too so i used them, only problem was the first ring is a different size between small & bigport
    Whyyy u do dis toyota!
    I used all the others & found the one which came out of the engine, they looked fine so once i gave them a clean they went in
    Pitty you can't buy rings individually
    Also
    TRD banner + domo
    (yes i know its dirty)
  5. #65
    Ade
    SYD, Inner west
    looking good champ.
    where did you get the windscreen banner?
    i've been looking for one for ages!
    AE86....robbing me! check the build.
    http://www.ae86drivingclub.com.au/fo...read.php?t=445
  6. #66
    Aug 2014
    Harry
    South Australia
    Barossa
    Thanks man!
    Appreciated it
    Got it from here
    All different colours too
    Not bad of a price also
    Compared to others ive seen
  7. #67
    Ade
    SYD, Inner west
    That's awesome. I have only managed to find them around the $60+ mark!
    Sent from my HTC_PN071 using Tapatalk
  8. #68
    Aug 2014
    Harry
    South Australia
    Barossa
    Bay is painted!
    Been slowly putting it all back together
    Bought a bm44 non abs
    Waiting on that to arrive then tuck the brake lines up behind the fender
  9. #69
    Will
    Nairne
    Looks epic mate! Doing an awesome job
  10. #70
    Aug 2014
    Harry
    South Australia
    Barossa
    Thanks
    Shes getting there
  1. Harry's F20c AE86
    By Hazza in forum AE86 Owners Forums
    Last Post: 21st April 2012, 01:28 PM
  2. Harry's Diner
    By mikkas in forum General Topics (No Technical Questions)
    Last Post: 3rd February 2008, 10:42 PM
  3. New Harry Potter Movie
    By RB MaNiAc in forum Offtopic Discussions
    Last Post: 18th July 2007, 11:21 PM
