Located BRISBANE/SUNNY COAST
PRICE : $7000 but looking to trade.
Looking to trade. S13 DET , BMW E30, another older KE (KE10/20) , Manual Cressida. Older VTEC Civic. Older Japanese or possibly cool older euro. My garage isnt that big so needs to be something similar in size.
Not interested in Falcodores, bikes or 4x4's so please dont bother.
The 'rust' is a rust effect paint.
Stock bigport 4agze block
Stock head (possibly some work by previous owner who installed the cams)
HKS 264, 8.1mm lift cams (not dialed in yet)
8mm leads
SC14
Jasma plated unknown 4-2-1 stainless headers
2.5” custom exhaust wit CAT and sports muffler
New timing belt
New timing belt sprocket and keyway.
Adjustable cam gears (cams not dialled in)
FMIC 300x300 inlet and outlet same side.
2.5” intercooler piping.
Blitz blow off valve plumbed back to airbox (still does the pshh)
N/A Throttle body (larger than stock) relocated after supercharger,
N/A inlet manifold (cut and shut)
7MGTE injectors
VN airbox with K&N filter
Chrome catch can
Chrome overflow
Strut brace (unknown brand)
Oil filter relocation with oil cooler, braided lines. Thermostat not mounted yet.
Oil temp and boost gauge
Tacho dash with digital voltmeter mounted in place of digital clock. Speedo and tacho are AE93 items custom fitted, 200kph and 9000rpm.
XT130 struts shortened 40mm.
HSD coilover kit 6Kg
needle bearing spring hats
T3 camber plates
T3 roll center adjusters
Reco'd Sumitomo XT130 brake calipers
Monro GT gas short stroke front
New brake lines
Full superpro front bush kit
Custom 90mm zero ackerman XT130 steering arms
New tie rod ends
New RA60 rack ends
AJPS lock spacer
Rebuilt dizzy
rebuilt alternator
Genuine JDM quad lights and grill, KE20 badge
Semi sealed bulbs
Headlight relay kit
Retro vintage mesh headlight covers with yellow vinyl inner wrap on high beams
Madhouse front lip
JDM heart guard indicators.
Chrome custom weather shields
W55 gearbox
AE71 pedal box, strengthened
Extreme Ceramic HD clutch ($900 worth)
Walbro 225 fuel pump inline.
Cube W55 short shifter
Black aluminium dildo shifter.
Genuine KE70 Toyota rear venetians
KE55 front/rear chrome bar
HSD Base height adjustable and damper adjustable rear shocks
Celica ST ultra low springs 4.6kg rear un-cut
Whiteline adjustable panhard
DX/GL tail lights (repro)
TRD style FPR rear wing
Rota RKR 15x9 zero
195/50/15 Kumho KU31 front, Zetum rear
aftermarket horn hidden in wheel well
aftermarket washer bottle hidden in wheel well
charcoal canister hidden in wheel well
all wiring tucked but still accessible where needed.
Battery relocation to boot
Fuel and boot poppers
Autotecnica Monza fixed backs
Mint carpet
6” splits in front doors on custom mounts
6x9” Kickers in the custom parcel tray
12” sub in box, 4channel and 2 channel amp
Head unit in under dash piece
Black dash pad hiding one small crack.
Central locking on front doors, wiring there for rears (broke an actuator so didn’t install)
New central locking kit can be supplied
Chrome Fender mirrors
And lots of shit I have probably forgot.
Spares:
2 T series zenki diffs
KAAZ 2 way zenki LSD center.
spare SC12
Whatever else I have KE70 related.
Mod plated for engine, brakes and seats.
Car is currently rego'd, could possibly organise a RWC. No it is not P plate legal. Build the KAAZ diff and you're laughing.
Currently has a slight diff knock but is still 100% driveable. (I daily drive it to work)
No longer has the rear roof spoiler but I can make another one, also has chrome mirrors now.
PM ME OR SMS 0455943 five seven two
If you need pictures of anything specific just let me know.
I will not part anything either the whole lot goes or none of it goes.
$5000 without wheels KAAZ and steering wheel if gone asap.
