Results 1 to 10 of 13
Thread: Swapping Ring and Pinion gears
    Senior Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Swapping Ring and Pinion gears
    My LN4* hilux diff ratio is 4.875 (R=39, P=8). however i need to change it to 3.91. Now, i have checked on toyodiy.com and most hilux(es) that came with a 3.9 diff had Ring gear=39 teeth, Pinion=10 teeth.
    Should i just look for another hilux Pinion with 10 teeth and swap it into my diff without changing the Crown ring sisnce it already has the 39 teeth?
    max.
    Mar 2013
    andrew
    perth
    no, get new ring gear and pinion.
    old ones are worn together.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Makes sense. thanks
    West
    They are matched sets from the day they are made, nobody ever sells just the crown wheel new or just the pinion. The only people selling them separate are ebay scammers that want to rip off kids that don't know the difference.
    Diff gears are surprisingly complex, even though they are quite simple on the surface. Each gear is stamped with markings which let the person know who is setting it up what is required.
    But yeah as the others have said, crown wheel and pinion are a pair and really can't be separated as they wear evenly together.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    been to the wreckers today trying to find a 3.91 hilux diff (crown and pinion set) but no luck yet. Will try again 2moro. Otherwise i might have to buy a new set (expensive)
    thanks everyone.
    West
    Hilux has a few different diff sizes so be careful and check the build plate to make sure if its G E or T series. Plus a front diff will spin the other way so dont get caught out with those.
    Mar 2013
    andrew
    perth
    i bought new g series 3.73:1 cw/p from local diff shop for around 400$
    West
    Thats pretty decent especially if its a good make.
    Mar 2013
    andrew
    perth
    drivetech 4x4 was the brand, i had never heard of them.
  1. crown &pinion gears for t series
    By crazy nanna in forum Cars or Parts Wanted
    Last Post: 7th March 2013, 08:49 PM
  2. 4.3 4.1 diff centre, ring gear pinion for t series vic
    By armc89 in forum Cars or Parts Wanted
    Last Post: 28th February 2012, 08:17 PM
  3. WTB: T Series, 4.1 Ring And Pinion
    By dogan in forum Cars or Parts Wanted
    Last Post: 15th November 2011, 01:10 AM
  4. Replies: 2
    Last Post: 17th October 2011, 11:41 AM
  5. [VIC] 4.7 Ring & Pinion, JDM Tailshaft for T-series diff
    By tuned86 in forum Car Parts For Sale
    Last Post: 20th November 2009, 08:03 PM
