Results 1 to 5 of 5
Thread: Thoughts on EFI setup for the track
    Senior Member Mad RS's Avatar
    Queensland
    Wynnum
    Default Thoughts on EFI setup for the track
    Hey Peeps,
    I need to setup my car with a proper EFI setup. The car is going to be used on the track so a boot mounted setup would be costly (having to build covers/fire wall for the whole setup). The other issue I have is that the instrument cluster has many issues so I am looking at ripping it out (speedo doesn't work, aftermarket tacho (factory not connected) and the fuel gauge is seized).
    So what I am looking at is a proper EFI setup and running a aftermarket fuel gauge in a custom gauge cluster (tacho, oil pressure, boost pressure and fuel gauge).
    What I have found so far:
    1. Ae86 JDM fuel tank with good in tank pump
    2. AJPS under car surge tank (need low pressure + high pressure pump, the surge tank and wiring)
    3. S13 tank with good in tank pump (gauge apparently easier to find that suits S13 sender + larger tank capacity)
    Thoughts??
    Run what ya brung...............and make damn sure ya brung enough!!!!
    Aug 2010
    Geoff
    mt dandenong
    Ajps setup. Cant beat a surge tank for track use and its been well designed to be out of the way etc
    Vl pump, ajps surge should be enough. Others recommend a carter lift pump but I don't think they are necessary personally
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I also agree with the above, I think the JDM tanks are a bad option because they are expensive and then they still won't baffle the fuel enough for track use. With the surge tank from Dave you keep the fumes out of the car and you can leave your existing tank as is without any surge issues ever. As for fuel pumps I suggest the two that come standard on a VL and used in the same way- one internal and one external.
    West
    I went a bit overboard with mine, as I had a JDM tank in my last car and while its fine for 99% of driving theres the odd moment when you wish it worked better. So now I have a JDM tank with an adm pickup from the swirl pot inside, and then it gets lifted into an external surge tank, then that's sucked dry by a Bosch hp pump and then returns from the rail into the surge tank, which overflows into the main tank. With the swirl pot in the tank feeding the lift pump I should be able to run it really low and never have an issue with fuel surge or supply.
  1. BEAMS EFI Setup
    By Jordain in forum Technical - Questions
    Last Post: 10th October 2013, 09:12 PM
  2. WTB efi fuel pump setup for my 86
    By doriking in forum Cars or Parts Wanted
    Last Post: 8th October 2009, 08:47 PM
  3. Thoughts and help on this setup?
    By Hazzard in forum General Topics (No Technical Questions)
    Last Post: 28th August 2009, 10:22 PM
  4. efi fuel setup
    By duggy in forum Car Parts For Sale
    Last Post: 16th August 2009, 09:33 PM
  5. K motor efi complete setup
    By Ben Mr..hachiroku in forum Car Parts For Sale
    Last Post: 13th December 2007, 08:06 PM
