Okay, Picked up a donor car Sunday morning that has sat in a shed for the past year or so, it was a paddock basher that did jumps and other cool stuff. Has a couple of good bits, tacho dash, air back set up in the rear.
Pulled the motor and box out In the arvo and cleaned it up a little.
This morning I split the engine and box, used the better of the two clutches and dropped it in. Got it all together and what not and then saw that the looms are different, the wagons an 86 model so has all the enviro shit. but it also had an electronic dizzy and O2 sensor where as the other doesn't.
Tonight I swapped the Dizzy's and the TPS sensor (plugs are different), got everything hooked up apart from 2 plugs that I couldn't work out where'd they go, it cranks all sweet but wouldn't start, there's shit all fuel if any so I put it down to that. But for good measure I checked for spark and there isn't any.............. Dang it.
So tomorrow I'll be checking everything over trying to get it to run, I have 2 of everything so I should be able to fault find and work it out. Hoping to get it in for a roadworthy Wednesday morning. Then I'll take it for a long drive to blow the cobwebs out of it.
