Results 1 to 3 of 3
Thread: Water/Methanol Injection
    Senior Member Mad RS's Avatar
    Queensland
    Wynnum
    Default Water/Methanol Injection
    Hey Peeps,
    Has anyone one here had a play with water/methanol injection?? I have been reading up on different kits and installations and it seems like a very good idea with only a few draw backs. Has anyone tried it??
    Run what ya brung...............and make damn sure ya brung enough!!!!
    Oldschool Member FORDISGAY's Avatar
    Oct 2006
    nick
    Qld
    Deception Bay
    Yup water injection is awesome. More effective than e85 in my personal opinion. I tuning my car one night (rb30det skyline) and it had some pretty decent 440cc injectors in it. I had a 50/50 mix of e85 and 98 and to get my car running mint afrs i had maxed out my injector duty cycle at about 10psi boost at high rpm.
    I then used up all of the fuel and got some 98 i was trimming back all the fuel tables and found that i could run the same boost and same power running at 70% injector duty cycle.
    Now at this point if i had installed the water injector kit (which i didn't because i didn't have the correct nozzle sizes) I would have been able to run one whole point leaner afrs without having to worry about detonating (From 12.8 to 13.8) and i could have thrown much more timing advance without detonation. All this plus the benefit of having cooler cylinder temps and a constantly steam blasted carbon free combustion chamber.
    All these benefits with nothing much really to lose.
    I hear a lot from people with excuses about why they didn't install water injection. Oh im not using this as a drag car. Oh e85 is god to me. I have a big intercooler im good mate. All just uneducated comments that prove most of these guys are painfully ignorant , or simply just couldn't be bothered to learn about how it works.
    You get people who can't justify spending 200-400 bux on something that none of their mates are smart enough to use on their cars. Instead they will go spend 1000 bux on a e85 fuel system with swirl pot and shiny lines big expensive untunable injectors. It doesn't make much sense to me.
    Eddie
    Winner.
    But in seriousness, a properly setup water/meth injection can be a very good thing. It is quite complex to set one up properly with failsafes in case you clog a nozzle or run out of water. To be honest, the cost of setting it up for e85 vs water inj is very similar.
  1. Direct Port Injection Explained
    Last Post: 20th August 2012, 02:48 PM
  2. out board injection
    By Celica RA45 in forum Technical - Questions
    Last Post: 3rd December 2010, 04:25 PM
  3. Liquid Propane Gas Injection
    By sundee in forum Technical - Questions
    Last Post: 8th February 2010, 03:33 PM
  4. water injection with quad throttle bodies
    By dr1ft-pig in forum Technical - Questions
    Last Post: 21st February 2008, 11:52 AM
