Results 1 to 9 of 9
Thread: AE92>ADM86 Intake manifold questions
    Aug 2012
    Braden
    Bendihoe
    Default AE92>ADM86 Intake manifold questions
    Hey dudes ! In the middle of completing my first engine swap. Running Ae92 smallport in ADM86.
    Does anyone have a photo or can tell me what happens with all the lines on the intake manifold and what they run too as I basically have no idea whats what.
    Photo is current setup.
    One on the back of the manifold goes to the map sensor.. Others i'm pretty sure can be blocked up because they are used for egr valves + power steering idle ups.
    Elite rthy's Avatar
    Leo
    Tulla
    hopefully you can see the 3 vac outlet, 1 is closed off and one to the fuel reg (like whats already connected) then goes to the MAP sensor
    you can piss off that copper hose thing on the back of the manifold
    also the big 3/8 hose fitting which goes to the booster on inlet 1
    your nipple to the rocker cover has been blocked off
    on the TB there should be one marked 'c' to go to the charcoal canister and the others can be blocked
    the 2 under the tb goes to water to melt the wax
    The manifold shown is a smallport, but yeah, agree use the black connector for the map sensor.
    Aug 2012
    Braden
    Bendihoe
    Okay so got a fair understanding now.
    Runner 1 black nipple goes to booster
    the side black thing hooks onto the rear fuel reg and MAP sensor
    rempve the rear copper hose
    I made a plate to block off all the wax shit except for one of the nipples on the TB
    Questions:
    On the front of the fuel rail it's got that O ended hose bolted onto the rail and then goes to another O fitting on the other end, what happens with this as somehow I've gotta have it hooked up to fuel return ?
    Fuel return comes out the back of the pressure regulator, use efi hose and a clamp and your done
    Aug 2012
    Braden
    Bendihoe
    Okay, so what for entry then?
    Elite rthy's Avatar
    Leo
    Tulla
    the long hose is the inlet, highpressure 8mm (4ac is 6mm lines but should be fine)
    that short bit is the fuel reg outlet low ressure 4mm?
    Aug 2012
    Braden
    Bendihoe
    Sweet. Thanks for the answers guys. Appreciate it !
  1. 4AGE Intake Piping Questions
    By NoScreen in forum Technical - Questions
    Last Post: 28th August 2014, 06:35 PM
  2. Smallport intake manifold questions
    By johnny2 in forum Technical - Questions
    Last Post: 25th August 2014, 12:10 AM
  3. Replies: 4
    Last Post: 1st September 2010, 01:47 PM
  4. RWD Intake Manifold and FWD Intake manifold
    By omygtr in forum Car Parts For Sale
    Last Post: 17th April 2009, 07:13 PM
  5. WTB:RWD 4age intake manifold, exhaust manifold
    By djscheppy in forum Cars or Parts Wanted
    Last Post: 8th June 2008, 06:39 PM
