Results 1 to 7 of 7
Thread: Repairing Rear Quarter Panel Help
    Member 0036's Avatar
    Mar 2015
    Steve
    ACT
    Belconnen
    Default Repairing Rear Quarter Panel Help
    Hey Guys,
    So im about fix up my rear quarter panels on my AE86 and i wanted to get some feedback/ideas on how to fix it
    So these are my rear quarter panels:
    Right side is crumpled, and has had holes drilled in it, to mount a fiberglass over fender (all previous owner)
    Left side only has the drill holes
    So basically i cant weld and dont own a welder so anything welding related is out.
    The crumpled part cant be hammered out anymore, so i will fix whats left of the damage with bog, but its the drill holes that im not sure what to do with? I was thinking, counter-sinking all the holes then solder really fine chicken wire over them, then use bog over the top of that?
    I know alot of people are against bog, but i dont have alot of money and just want to be able to get my car on the road so i dont care.
    any help/ideas would be greatly appreciated!
    Cheers,
    Steve
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    First off you will defiantly need to seal the steel with something like POR15. With the holes in the panels lightly tap in with a hammer and wipe over with a small amount of " need it" (epoxy steel substitute).
    The last thing you want is all the filler falling off, cause there will be many hours spent shaping the filler to get it looking any good. There may be areas with an inch or so thick with bog. Your not the first person to load up a panel with bog to make it look original. It's all about the prep.
    Mar 2015
    Steve
    ACT
    Belconnen
    What is POR15 exactly, ive heard of it before but never used it?
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    Its a durable rust resistant paint from the US. In Aus you can get stuff called KBS which is pretty much the same thing, and cheaper (but still great quality). Jb weld is like bog but its mostly metal.. you could try that for the holes
    Member phoenix's Avatar
    Nick
    I would try to solder or braise the holes up rather than bog them up.
    You can get a blowtorch from bunnings that is more than capable of heating up the metal enough to get the solder or braising rods flowing
    Formerly 86 Nick
    Nick
    Alternatively you could try to tap the holes with a hammer just enough to lower them and fill them with steel pop rivets then bog over the top to smooth them out
    Formerly 86 Nick
    Single sided spot welder will prob be the easiest way to fill in those holes, you can use a mig with a bit of aluminimum behind it, but you'll have allot more grinding to do.
    The dent itself will take time with spoons / dollies and that. Use black spray paint to give you a line to work towards.
  1. wanted: toytoa sprinter rear quarter panel
    By shawty228 in forum Cars or Parts Wanted
    Last Post: 19th March 2012, 04:37 PM
  2. WTB New rear right quarter panel
    By _sawyer_ in forum General Topics (No Technical Questions)
    Last Post: 18th June 2010, 05:31 PM
  3. ae86 rear quarter panel [NSW]
    By drift kid in forum Cars or Parts Wanted
    Last Post: 20th July 2009, 12:25 PM
  4. Rear Quarter Panel Windows!!!
    By Maloney in forum Technical - Questions
    Last Post: 7th June 2009, 11:49 PM
  5. How do i cut off a rear quarter panel?
    By fozz in forum Technical - Questions
    Last Post: 22nd May 2006, 08:25 PM
