Results 1 to 9 of 9
Thread: KE70 Sedan - Sleeper looks with all the goods QLD (Bris)
    Mar 2011
    Ali
    Default KE70 Sedan - Sleeper looks with all the goods QLD (Bris)
    I needs to sell my KE70 Sedan to fund Pano build, so, sadly this has to go.
    BODY/EXTERIOR:
    Quad light conversion
    MK1 Golf 2 piece lower lip
    Rear window venetian blind
    Towbar installed (for rear extra chassis rigidity)
    Vinyl black "corolla" pin-striping
    *Paint is a bit rough, but presents ok.
    INTERIOR:
    Factory Tacho Dash (modified to work with current coil set up)
    Blue material, well maintained.
    Twin Cam Steering Wheel
    Recaro driver seat - Retrimmed, with all new genuine Recaro foams installed on factory Recaro/Toyota Runner!
    *Has speakers installed into front doors on beige mounting base, looks a bit out of place?
    CD/USB Player
    ENGINE:
    St 20V in RWD format
    Open quads fitted with bell mouth trumpets, ITG filter socks and internal springs
    Sard adjustable FPR
    T2 Alloy lightweight crank pulley and water pump under drive pulley
    Laser cut alloy "Idle speed control valve deletion plate" installed to top of ITB.
    All ITB hoses replaced with blue silicon with use of a vacuum block - cleaned up the factory rats nest.
    Dizzy blank plate
    Thermostat bypass plate
    Rear waterpipe block
    RWD 4A engine mounts
    Wrapped Stainless steel 4-1 header
    Microtech ECU and Dash unit with wiring full loom to suit St20V
    Cusco Strut brace
    AE71 Alloy radiator mounted laser cut brackets with rubber mounting grommets.
    16" Toyota Denso radiator mounted to rad on stainless steel brackets.
    Internal regulator alternator wiring mod
    Speedflow fittings used where possible
    Brand new oil filter and oil installed.
    DRIVETRAIN:
    Clutch master cyl - fire wall mod / hole
    AE71 Pedal Box with brand new T18 master cylinder
    Blue braided clutch line - master to slave
    Brand new slave cyl
    W56 with A-Z customs T50 Bell adapter – shifter hole requires no cutting at all on manual or auto xE7x, perfect position
    JDM T50 bell (Clutch fork on Driver side)
    ST Flywheel (212mm)
    Exceddy 4 puck solid brass button clutch
    Tailshaft to suit W series / BW Diff
    Comes with S2 T18 diff with stock T18 tailshaft included, needs front yoke changed to suit w series box.
    SUSPENSION:
    Lowered springs, falcon chopped rears
    New AJPS motorsport Tie rods
    New AJPS rack spacer
    New AJPS poly rack bushes
    Sigma Control arms with modded bushes to suit AE71 Xmember
    Brand new ball joints installed.
    WHEELS:
    5 x CSX/DXX Alloy's - BF Goodrich tyres with very good tread.
    Rego until December
    No mod plate for conversion or Recaro seat.
    There really is not an issue with getting this done, I just haven't been stuffed to do it.
    The Recaro seat is mounted on a factory Recaro/Toyota Surf rail that has been tweaked to make it fit.
    No cutting, welding or extra holes were required to install, and it picks up on the factory xE7x mounting points.
    The engine xmember is a factory AE71 4A item, as are the engine mounts and pedal box used.
    The W series gearbox mount is custom, and has been done professionally.
    Exhaust after extractor is bit average.
    I am not in a rush to sell.
    EOI for now
    0449 838 779
    Ali
    Pictures taken 02/06/2015.
    Engine bay pictures will follow soon
    Mar 2011
    Ali
    Default Pictures
ID:	35407   Click image for larger version.
ID:	35408   Click image for larger version.
ID:	35409   Click image for larger version.
ID:	35410   Click image for larger version.
    Veteran AJPS's Avatar
    Lonsdale
    looks good mate
    hope it goes to a good home
    Mar 2011
    Ali
    I appreciate that Dave, thanks man!
    This is only advertised on AE86DC, yall get first dibs.
    I really don't want to split it up, but if it does come to that, I'll post up in here first.
    Ali
    Mar 2011
    Ali
    Updated photos.
    Mar 2011
    Ali
    Still available.
    Mar 2011
    Ali
    No Longer for sale!
    Mar 2012
    G
    I saw this on the back of a truck in Broadbeach this morning. How many kms on the 20v?
    Mar 2011
    Ali
    Unknown Kms on the ST, when I cracked the valve cover open, its was nice and gold inside.
    Compression showed 190 190 185 190
    leak down showed 1,2 and 4 equal, no.3 had slight intake valve leak, was 5% but all in spec.
    Its been sold, that was the tilt tray taken her to new owners.
    Ali
  1. [QLD] KE70 Panelvan, Supercharged 4A-GZE sleeper drifter
    By FORDISGAY in forum Cars for Sale (Toyota Only)
    Last Post: 27th April 2015, 09:41 AM
  2. 1983 KE70 Sedan - BRIS NORTH. $800 or MAKE AN OFFER!!
    By Dazzle86 in forum Cars for Sale (Toyota Only)
    Last Post: 26th November 2013, 07:30 PM
  3. QLD FS ke70 part out got the goods
    By jackthecat in forum Car Parts For Sale
    Last Post: 21st November 2013, 08:13 PM
  4. [BRIS] S14 with the goods
    By killabeez_1985 in forum Cars for Sale (Not Toyotas)
    Last Post: 1st October 2013, 04:18 PM
  5. (QLD) Daily Ke70 with all the goods. Except a 4age......
    By wagonlife in forum Cars for Sale (Toyota Only)
    Last Post: 18th August 2013, 09:25 AM
