Results 1 to 6 of 6
Thread: 7agte with w58 gearbox. Which clutch?
    Jan 2013
    Martin
    Berlin
    Prenzlauer Berg
    Germany
    Default 7agte with w58 gearbox. Which clutch?
    Hello which clutch and pressure plate can I take, when I use a w58 gearbox behind a 7agte?
    Cheers Martin
    Lots of good info in this thread here
    Jan 2013
    Martin
    Berlin
    Prenzlauer Berg
    Germany
    A friend told me that, the clutch from my 4agte will fit the 7a engine. I need only the flywheel from the 7a.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Here is a light weight 6 bolt flywheel, only 200mm though:
    You need a friction disk to suit the W-box and the pressure plate to suit the flywheel.
    The original 7afe flywheel is 212mm which is easier to work with and will give you a higher torque rating. Once you decide which diameter clutch you are after then contact me and I can give you the info. I suggest email because I often miss notifications of a PM.
    If you have any other questions other than part numbers then feel free to ask here.
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    I run a toda 212mm flywheel with an exedy hd pressure plate to suit an ae92 and a Cushioned button clutch disc to suit a RN40 hilux. All bolt on with no mods.
    This in on my 7agte->w55.
    Jan 2013
    Martin
    Berlin
    Prenzlauer Berg
    Germany
    Nice One
  1. W58 Gearbox conversion (Clutch problem)
    By Intense in forum Technical - Questions
    Last Post: 15th June 2012, 12:43 AM
  2. clutch pedal/ gearbox maybe clutch plate issues
    Last Post: 28th January 2012, 12:28 PM
  3. 4agze to W58 gearbox flywheel and clutch set ups
    By reggea in forum Technical - Questions
    Last Post: 15th June 2010, 08:35 AM
  4. W58 GEARBOX ? WHAT FLY WHEEL/ clutch
    By AIROCOBRA in forum Technical - Questions
    Last Post: 8th October 2009, 07:37 PM
