Results 1 to 6 of 6
Thread: steering rack problem
    Member Houd Chaudhary's Avatar
    Jan 2015
    Houd
    Default steering rack problem
    Can someone come over to my place to fit in the steering rack I don't know wats going on, i was told to unbolt and pull off, so I did and only half of it came out. So I pulled the other half off the other steering rack and when I try to put it in, it won't move.
    Veteran McLEVIN's Avatar
    Nov 2010
    I have no idea on what you are talking about or why you are changing racks
    But you have to pull the whole rack out.
    Looks like this
    First you have to undo from the steering yoke in the engine bay.
    Then im not sure if you have to but undo the rubber boot at the fire wall.
    Sounds as if you are trying to remove just the housing..you cant unless you take the indicator stalk and ignition/steering lock component off.
    MOPAR or no car!
    Nov 2010
    This is how its assembled..
    MOPAR or no car!
    Jan 2015
    Houd
    Do u no anyone that can do it for me?
    West
    you can but you will have to learn patience and attention to detail. The only thing hard is that the bolt on the uni joint has to be all the way out for the steering to come apart thewre, otherwise its a simple bolt in and bolt out affair. By the way, thats the steering column not the rack.
    Jan 2015
    Houd
    I'm new still leaning how to do a lot of things.
  1. AE71/AE86 steering rack (quick rack if possible)
    By stixy in forum Cars or Parts Wanted
    Last Post: 21st April 2014, 08:13 PM
  2. [BRIS] WTB! Urgent! Steering Rack with good rack ends!
    By Dazzle86 in forum Cars or Parts Wanted
    Last Post: 15th November 2013, 08:55 PM
  3. Replies: 1
    Last Post: 10th September 2013, 09:10 PM
  4. Replies: 2
    Last Post: 22nd August 2013, 03:03 PM
  5. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
