Results 1 to 9 of 9
Thread: Removing Sump From 4AC
    Aug 2015
    Hash
    New South Wales
    Default Removing Sump From 4AC
    Gday guys,
    Just bought an ADM Ae86 last week. I've encountered a few issues since.
    It seems to have a quite severe leak through the sump gasket, which I am currently in the process of trying to take out with a mate. There are two bolts remaining which seem impossible to get to. They are sandwiched behind a blue mount of some sort which is bolted on from the back of the engine to the side of the engine. We have tried jacking the transmission up for clearance but this has not helped.
    Does anyone have any tips for removing the sump off a 4ac?
    Car is currently not driveable- would greatly appreciate any advice!
    Thanks,
    Hashiroku
    Veteran timbo's Avatar
    Tim?
    Wild West
    In my experience you'll need to lift the engine up off the cross member or take the engine out all together.
    West
    I drilled a sneaky hole through a single thickness area of the member and was able to access it through that on my conversion, just an idea.
    If You've just bought an old car you more than likely will want to pull it out, clean it, do more than just the sump seal, and put it back in. Its a lot easier with it out if you are doing multiple things.
    Tim?
    Wild West
    That's too sneaky!
    Aug 2015
    Hash
    New South Wales
    Genius!
    Thanks for your contributions, guys- ended up putting the sump bolts back up as we simply could not get the final of four bolts holding the brace off. Still as leaky as ever haha.
    Used D-spanners, ratchets, and 3 different visegrips-all to no avail. Ended up merely severely rounding the nut. All after a liberal and overnight dousing of WD40.
    Car is now back up and running, so I'm pretty stoked with that at least!
    Tim?
    Wild West
    Fuck I'd be taking that back to the shop or emailing Irwin!
    Aug 2015
    Hash
    New South Wales
    I bought that on the day as well lol. much disappoint.
    Aug 2015
    Hash
    New South Wales
ID:	35820 : '(
    Veteran drift kid's Avatar
    Glossodia
    I have never seen a vice grip break like that, that is incredible
    Sent from my D6653 using Tapatalk
  1. in need of 4ac sump (brisbane area)
    By crazy nanna in forum Cars or Parts Wanted
    Last Post: 11th October 2009, 10:44 AM
  2. WTB: 4ag or 4ac Sump in SA
    By Patric in forum Cars or Parts Wanted
    Last Post: 22nd July 2009, 09:44 PM
  3. WTD : 4ac sump, and other parts... [melb]
    By trungster in forum Cars or Parts Wanted
    Last Post: 8th June 2009, 07:37 PM
  4. Removing OLD 4ac
    By gumbie in forum Technical - Questions
    Last Post: 9th February 2009, 08:33 PM
  5. 4ac/ge bare block an sump
    By hilux05 in forum Cars or Parts Wanted
    Last Post: 23rd December 2008, 09:55 AM
