Results 1 to 2 of 2
Thread: Ke70 4agte forged 20v
    Dec 2012
    Arana Hills
    Default Ke70 4agte forged 20v
    For Sale: Ke70 20v 4agte
    Engine:
    -Silvertop 4age 20v
    -Forged weisco pistons
    -Arp head bolts.
    -cometic head gasket
    -Head has been reconditioned
    -balanced bottom end
    -Supra 450cc injectors
    -Custom steam pipe manifold.
    -Garret gt28r ball bearing turbo (400hp) in great condition. With braided oil lines
    -Tial 38 mm external waste gate
    -Custom plenum
    -Custom ARE intercooler
    -Crank angle sensor conversion.
    -Malpasi fuel reg
    -Link g4 storm ecu. Near new with receipts. (3000km old)
    -Dual coil packs.
    -Tuned by Chapman's auto cooroy. Safe tune at 203hp at wheels on 12psi. (Have dyno chart) Can get more out of it if wanted.
    -3" exhaust. With under diff bend.
    -Upgraded 3 core radiator with thermo fan
    -oil cooler
    Driveline
    -4 puck sprung button clutch with upgraded pressure plate. Done by direct clutches Albion. 3000km old.
    -hydraulic clutch line pedal box and new clutch slave cylinder
    -supra W series gearbox. Reconditioned with new gears, seals, gear lever bush and synchros. Feels like new. 3000km old. With receipts.
    -Custom gearbox cross member to bolt straight to ke70.
    -4 a to w adaptor bell housing (cost $700 new)
    -1 piece custom tail shaft.
    -r31 skyline disk brake diff with mounts converted to suit ke70. Tight recondition lsd. With receipts.
    Suspension.
    -s13 fron lower control arms, brakes, rotors,
    -base height and camber adjustable coilovers 6kg springs (1 needs reconditioning), adjustable rose jointed t3 castor arms.
    -bluebird tie rod ends
    -ajps 6kg rear springs
    -kyb short stroke shocks.
    -needs rear sway bar. Handles ok even with out one!
    -stock front sway bar
    Fuel
    -New lift pump
    -Bosh 044 fuel pump.
    -Surge tank.
    -Bigger feed fuel line.
    Body
    -Flared front guards
    -Rolled rear guards.
    -Rust been cut out of rear near tail lights bad bog repair job- will need to be redone if you care about how it looks. Some rust in lower 1/4 panel.
    -adr approved monza race seats with standard ke70 rails on them (legal)
    -battery in boot
    -roof racks
    -sports steering wheel and boss kit.
    -boost gauge
    -water temp gauge
    -doesn't come with the stereo head unit
    Car runs well. Comes with the white powder coated wheels. This car has a near new unbreakable driveline. It has all straight panels
    Needs:
    1 coilover fixed
    Wheel alignment.
    rear needs bog work tidy up
    rear sway bar
    Lots if money and time has been spent on this. Lots of items near new. Regretful sale. Selling due to purchase of another car. Wanting to sell as a complete running car. Will not part at this stage.
    Has mod plate for engine and turbo. Was registered in qld and was my daily. Never raced or been to drags. Sell unregistered.
    $6000 . .....FIRM....Arana hills Brisbane. Chris 0431 two nine seven 405
ID:	35899Click image for larger version.
ID:	35900Click image for larger version.
ID:	35901Click image for larger version.
ID:	35902Click image for larger version.
ID:	35905Click image for larger version.
ID:	35906Click image for larger version.
ID:	35903Click image for larger version.
    Dec 2012
    Arana Hills
    Back up for sale...
  1. neat ae86 - forged 20v heaps of goodies ;)
    By Oweis Muhammad in forum Cars for Sale (Toyota Only)
    Last Post: 1st April 2015, 08:26 PM
  2. Daims 20V 4AGTE KE70
    By Skid_KE70 in forum KE70 / AE71 Owners Forums
    Last Post: 27th June 2014, 03:18 PM
  3. Replies: 4
    Last Post: 13th September 2013, 02:17 PM
  4. 20v forged engin full rebuilt never started
    By 350hp4agte in forum Car Parts For Sale
    Last Post: 8th October 2009, 08:51 PM
  5. 20valve 4agte forged motor
    Last Post: 12th May 2008, 07:09 PM
