how much work to get it back on the road mate
ADM AE86 4agte (NSW)
Needs work...currently half stripped was going to do some rust (minor) repairs but given up due to no time or money.
Engine could do with a freshen up as it has been sitting for a while. Last started about 6 months ago before pulling parts off.
Details I received from previous owner: (work done by a workshop in Lismore)
- Gout filled block to prevent splitting under high boost
- Polished/prepped steel crank
- Argo rods
- Wisco pistons/rings 20thou
- High energy sump
- ARP main and head stud kit
- oversized ferrera valves
- Custom grind cams
- O ringed head with extensive porting etc
- Adj cam gears
- Titanium retainers
- Copper head gasket
- GT30 600hp Turbo
- Custom plenum
- Custom fuel rail
- 044 fuel pump
- 690cc injectors
- Surge tank
- Big throttle body
- Hidden away front mount
- braided lines
- Electric water pump with controller
- Power 3 core radiator
- 3 1/2inch exhaust
- Microtec lt8 with two bar map sensor
- ICE ignition
- Evo split race coils
- Microtec hand controller
- Eboost controller
- W58 Supra 5 speed gear box
- Solid centre clutch
- 1 piece tail shaft
- Hilux diff full spool 4.8 diff gears
- Heavy duty axles
- Rear tail shaft loop
- Sparco sprint v's
- Lowered king springs
- New shockies
- 165 14inch front runners
- Toyo 225 14inch rear
- Also have set of Mickey Thompson street slicks 235/60 with chasers
- fc rx7 front brakes
Originally came with dyno sheets for 240rwkw and 260rwkw on 16 and 19psi but have since been lost.
Have a heap more spares not listed best to come have a look. Will take some pictures of current state this weekend.
$8000 with everything.
Located Central Coast NSW
A lot. Best to come have a look at how much work but needs some rewiring everything engineered etc.
Noticed this on ebay as well...
Yes it is on ebay as well. There are a few more photos I just put up there that show what's stripped from the car at the moment. All of the parts still here though in boxes.
sold
