Results 1 to 3 of 3
Thread: Knock Sensor into 7 Rib Big-port 4AGE
    Aug 2011
    George
    Sutherland Shire
    Default Knock Sensor into 7 Rib Big-port 4AGE
    I'd like to wire a knock sensor into my Series 2 N/A Bigport.
    Will check a bigport block and have a look, but i'm pretty certain the casting is significantly different and you wouldn't be able to add one in the same location due to lack of meat to drill into.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Bigport blocks don't have anything on the block to support a knock sensor, in the past to add one I've welded a nut to the side of the block in the factory small-port position.
  1. 7 rib big port?
    By whips in forum Technical - Questions
    Last Post: 16th December 2012, 08:45 AM
  2. Replies: 0
    Last Post: 24th January 2011, 04:26 PM
  3. ae92 small port gze knock sensor, 4age alternator plug
    By Roo in forum Cars or Parts Wanted
    Last Post: 13th July 2008, 11:43 PM
