Results 1 to 8 of 8
Thread: Ke70 to ae86 front end
    Oct 2015
    Jayden
    Wa
    Woodvale
    Default Ke70 to ae86 front end
    Hey I'm trying to finalise my front end setup, so far I have shockworks coilovers on there way and a set of shortened power steering knuckles,
    i am unsure of what linkages and tie rods and all the other things I'll have to buy for the front end,
    found a set of t3 roll centre adjusters, will these be of any use to me? Thanks appreciate the help
    Hubs you'll need and I'm pretty sure you'll need brakes too.
    Oct 2015
    Jayden
    Wa
    Woodvale
    Buying hubs and stub axles and brakes soon I just don't know what else I need as in steering and suspension
    Veteran johl's Avatar
    Johl
    you may aswell get xt130 control arms with new bushes and ball joints when you put your new steering arms in. personally i would also buy a quick rack and some poly rack bushes. then you can just use off the shelf ae86 rack ends and tie rods and you shouldnt have to change anything in the front for a long time
    Eddie
    Rcas are needed if lowering the car a significant amount. If your control arms are parallel to the ground, you need them.
    You have lcas sorted? Options in order of longest are: xt130, ra40/60, ke70/ae86.
    Sent from my iPhone using Tapatalk
    Oct 2015
    Jayden
    Wa
    Woodvale
    Having insane amount of trouble trying to located some stub axles to bolt on to my new coilovers, got a set of xt130 lcas,
    all I need to know is what other parts I will need as in rack ends and tie rod ends and stuff, not too sure what it all looks like so it's making it harder for me to locate it
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Call or email Dave at AJPS.
    He will be able to give you answers and more than likely have all the parts new and available on the shelf.
    See Sponsors section.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    West
    Yeah or maybe learn about the front suspension, how it works, what the parts are and what they do in the stock system, and decide what you will change and why based on that. But you just want to skip to the spending money part? Seems odd to not consider research but to ask what to buy. What are your goals?
  1. Replies: 1
    Last Post: 14th August 2015, 09:53 PM
  2. fs - ke70 flat front end - ke70 strutbrace
    By aake in forum Car Parts For Sale
    Last Post: 21st March 2011, 07:46 PM
  3. WTB ke70/ae86/ae71 tube things between rack end and tie rod end
    By ke70dave in forum Cars or Parts Wanted
    Last Post: 25th June 2010, 06:01 PM
  4. ke70/ae86 front end
    By roady in forum General Topics (No Technical Questions)
    Last Post: 27th December 2007, 08:39 PM
