Results 1 to 9 of 9
Thread: Best Argon/CO2 mix for MIG welding AE86 steel?
    Junior Member Velociraptor's Avatar
    Oct 2015
    Antonio
    South East Melbourne
    Default Best Argon/CO2 mix for MIG welding AE86 steel?
    Hey everybody, first post.
    I am just learning to MIG, and am attacking the rust in my rear quarters.
    Can anybody advise me as to what the ideal gas would be? I have read that C25 (75% Argon, 25% CO2) works best for auto body work.
    Noooob
    It's mild steel you are welding so any argon mix will work well.
    Take your time and practice on non important panels first.
    Junior Member ke70+ae92's Avatar
    Jul 2009
    Nathan
    Penrith
    plus keep the heat low, its so easy to blow holes in such thin steel
    V6 TT KE70
    Bathurst
    Just to add to this...Where are people getting cheap gas from?
    Noooob
    I bought a bottle for around $300 and pay $80 for a refill. The bottle is around weist high
    Eddie
    Gasweld will have the purchasable bottles. Much better than hiring for the occasional user.
    Sent from my iPhone using Tapatalk
    Senior Member kaibeecee's Avatar
    Pete
    For body work 0.6mm wire is best
    75% Argon 25% C02 is preferable (aka argoshield lite/supashield 25 etc)
    purchasing a bottle and paying per refill is much better than shitty rental rates (~$12-20 per month)
    use lower amps, more wire for more solid tacks.
    Oldschool Member
    Jun 2008
    Philip
    Somerset
    Mendip
    UK
    Hello, I'm just starting to mig weld too, using a 93% Argon, 5% Carbon Dioxide, 2% Oxygen (Hobbyweld 5), seem to work well when I keep the gas pressure low and weld short lengths then let it cool down.
    Mar 2023
    Roeland
    Warszawa
    Woloska, Warszawa
    Poland
    Hello!
    MIG welding typically uses a shielding gas to protect the weld from the atmosphere, which can cause defects in the weld such as porosity, oxidation, and contamination. The choice of gas depends on the type of metal being welded, the welding wire used, and the welding conditions.
    As you mentioned, C25 (75% Argon, 25% CO2) is commonly used for MIG welding on auto body work because it provides good penetration and a stable arc. It is also a cost-effective option. However, other shielding gases such as 100% Argon or a mixture of Argon, CO2, and Oxygen may be better suited for welding certain metals such as aluminum.
    Ultimately, the choice of shielding gas depends on the specific welding application.
  1. Mig mild steel wire to stainless
    By Matt in forum Restoration / Body Work
    Last Post: 16th April 2014, 11:53 PM
  2. any interest in a short mig welding course?
    By Sam-Q in forum Melbourne & Vic Events and Discussion
    Last Post: 15th September 2009, 05:15 AM
  3. CO2 gas with a mig welder instead of Argon
    By Sam_Q in forum Technical - Questions
    Last Post: 25th June 2008, 10:44 PM
  4. Drift Mix
    By AE86.cn in forum Toyotas in the Media
    Last Post: 3rd May 2005, 05:56 PM
