Results 1 to 4 of 4
Thread: 4AGE Knock Sensor placement
    Aug 2011
    George
    Sutherland Shire
    Default 4AGE Knock Sensor placement
    Hi there; hoping someone can help me out with a query.
    I am planning to re-rebuild my Bluetop / Bigport with high-comp pistons (looking at 12:1 Spool kit).
    I want to run a knock sensor but while my block is a 7-rib (42mm journals) it is an early version and as such does not have a raised boss+tapped hole between bores 2 & 3; which is the standard mount pt for the OEM knock sensor.
    It does however have a raised boss between bores 1 & 2. Would an OEM GZE / AE111 type sensor mounted here give accurate readings?
    I have also heard that more modern screw-through type sensors as-per an SR20 unit may work better in non-std locations due to better microphone. . .
    Comments?
    It's easiest to find a 7rib block that supports the knock sensor
    West
    Yes maybe look for another block so you can build a bottom end while you keep the car on the road.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Pretty easy to weld a nut to the side of the block prior to boring and honing, I've done so several times in the past if you can't come across a good spare block.
  1. Knock Sensor into 7 Rib Big-port 4AGE
    By GeeEss in forum Technical - Questions
    Last Post: 8th October 2015, 05:06 PM
  2. WTB 4age knock sensor
    By blzbub666 in forum Cars or Parts Wanted
    Last Post: 15th December 2013, 04:43 PM
  3. Knock Sensor 4age
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 20th July 2013, 02:35 PM
  4. 4age knock sensor different?
    By wide s13 in forum Technical - Questions
    Last Post: 17th January 2009, 12:24 AM
  5. Need urgently, AE101 GZE Knock sensor or 7mgte Knock sensor
    By Nikkojoe in forum Cars or Parts Wanted
    Last Post: 23rd November 2007, 01:23 AM
