Results 1 to 2 of 2
Thread: [QLD] 4AGE RWD conversion parts, water and alterntor bracket etc
    Veteran slydar's Avatar
    Dimitri
    Default [QLD] 4AGE RWD conversion parts, water and alterntor bracket etc
    This is listed on ebay too, but i'll happily sell it to you direct to save the PP fee's.Click image for larger version.
ID:	36964Click image for larger version.
    RWD 4AGE Water Kit. $300+ post.
    This is neatest and most correct way to convert a FWD 4AGE to RWD
    Included is.
    Rear section of water pump
    Thermostat cover
    bypass pipe
    Top water neck
    rear water housing
    alternator bracket comeplete with through bolt and tension arm
    All essential parts needed to convert your 16v 4AGE to rwd. some parts useful for factory style RWD water conversion for 20v but some will be redundant (top water neck namely).
    Kit includes all basic parts needed. heater pipes and water pump not included, use your own pump or buy a new one.
    you can use any 4age/4ac water pump with this set up, just make sure you have the correct pulley to suit your pump.
    2nd picture shows outlet on rear housing is slightly crushed and has been cut. this is how i received it from Japan. I was not planning to use a heater and from the looks a rubber cap will go over this and seal with a clamp fine, but its an imperfection worth mentioning.
    78's
    Dimitri
    SOLD
    78's
  1. 4AGE RWD conversion kit, water parts and alternator bracket
    By slydar in forum Ebay Items - My Stuff
    Last Post: 11th August 2016, 05:23 PM
  2. (SA) WTB - 4age RWD water pump housing, RWD alternator Bracket
    By samboychips in forum Cars or Parts Wanted
    Last Post: 7th May 2013, 12:54 PM
  3. 16v 4age rwd alternator bracket and water pump pulley
    By kid redonkulous in forum Cars or Parts Wanted
    Last Post: 28th January 2013, 04:56 PM
  4. 4AGE FWD - Alternator, Bracket and Water Inlet Housing
    By dr_16v in forum Cars or Parts Wanted
    Last Post: 1st March 2012, 08:51 PM
  5. 4age pulleys/alternator/bracket & water pump
    By ru486 in forum Technical - Questions
    Last Post: 30th May 2010, 05:11 PM
