Results 1 to 4 of 4
Thread: JDM Corolla : Oil Cooler + Oil Temp Gauge
Threaded View
  1. #3
    Aug 2011
    George
    Sutherland Shire
    Thanks for that Jimmee; in that case I think I'll pull the trigger on the MRP thermostatic adapter @ below but will hold off getting their 15 row cooler for now.
    I'm not a big fan of running braided hose every-where & even though its a PITA will investigate feasibility of buying a manual Tube bender + Flare kit & replicate the OE hard-lines in AN-8 mild or stainless-steel. I'll also look for a cooler closer to the dims of the OE unit so I can use OE brace / mtg points.
    PS: On a related matter; my 4AGE is a big-port with no oil drain from the head to block. Is there any way I can tap an oil drain in the back of the head w/o getting metal shavings / swarf in the oil-ways? I've heard smearing the cutting bit with grease helps but am worried that even a minute amount of swarf may damage the bearings / engine.
  1. hks 60mm temp gauge 130$
    By toyoda in forum Car Parts For Sale
    Last Post: 17th December 2009, 08:35 PM
  2. jdm cat temp gauge
    By tim.duncan in forum Technical - Questions
    Last Post: 4th September 2008, 08:25 AM
  3. Oil temp Auto gauge 2' Electrical
    By reecegze in forum Car Parts For Sale
    Last Post: 2nd July 2008, 12:08 PM
  4. Omori mechanical oil temp gauge
    By racsov500 in forum Car Parts For Sale
    Last Post: 17th May 2008, 05:31 PM
  5. engine temp gauge
    By Johnny_08 in forum Technical - Questions
    Last Post: 18th April 2007, 11:59 PM
