Results 1 to 5 of 5
Thread: AE86 4AC converson to 4AGE
    Feb 2017
    Mitch
    Default AE86 4AC conversion to 4AGE
    Hi Guys,
    I am looking at purchasing a 1983 AE86 with a stock 4AC. I am highly interested to put a 4AGE in. I have heard that the swap just involves engine, wiring loom and ECU. The rest is supposedly universal such as gearbox, starter motor, engine mounts etc. Any advice on this topic would be highly appreciated.
    Thanks.
    Mitch.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    My advice, search.
    Here, toymods,club4ag,rollaclub,twincam.org
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Senior Member cbjaust's Avatar
    things to consider:
    bell housing to get the slave cylinder on the driver's side away from the exhaust
    accessory drive pulleys - 4A-GE has ribbed type, need alternator and A/C compressor pulleys to match crank pulley
    flywheel 8-bolt for 4A-GE vs 6-bolt for 4A-C
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    You also need to mod the fuel system for the higher injection pressure and return line. Dave W
    Its well worth the time to do it.. If you buy a jap conversion the the clutch is moved, but you can shield it from the exhaust / run a sleave.
    It's been covered heaps of times, but a summarised version of this swap is.
    * Remove old motor / box.
    * Remove remote voltage reg for alternator
    * Bolt 4age up to t50, if using FWD don't forget the spigot bearing in the crank
    * Add heat shield to clutch near exhaust
    * Sort out fuel system ( AJPS do a neat solution with their surge tanks)
    * Install motor
    * Modify the exhaust
    * Wire up and drive
  1. Replies: 7
    Last Post: 30th April 2014, 12:43 AM
  2. QLD Sunny Coast - AE86 4age exhaust may suit 4age keto
    By JDMBenji in forum Car Parts For Sale
    Last Post: 14th April 2013, 08:39 PM
  3. Replies: 2
    Last Post: 2nd September 2012, 08:44 PM
  4. 20V RWD Converson - Bottom Radiator Hose?
    By Futo_gt86 in forum Technical - Questions
    Last Post: 25th October 2011, 12:46 AM
  5. (vic)- ae86 / ae71 / ke70 .... manual converson complete set.
    By ghettorolla in forum Car Parts For Sale
    Last Post: 17th August 2011, 03:35 PM
Tags for this Thread
