Results 1 to 5 of 5
Thread: f312 has been bought and now just a few questions...
    Jul 2009
    Tim
    Mt Druitt
    Default f312 has been bought and now just a few questions...
    hey today i bought an f312 diff from an mx13 corona, now as far as i can see i need to weld up a plate thingy where the spring is meant to sit (due to it being cut off but i did look like it was in the wrong place anyway), and if i put my whole brake setup from my ke70 onto that rear end then everything will bolt up right?
    just after some clarification
    ohh yeah and a 2way WOOP WOOP!!
    Thanks
    Tim
    Jonathan
    I doubt it will all just bolt up. But you can make anything work if you live on a farm (access to welder, grinder, tools etc).
    What is the exact question again?
    Jul 2009
    Tim
    Mt Druitt
    well i went on this website....
    and i was looking for an f series that would suit my ke70, this mx13 diff (f312) is the same width as the ke70's (1410mm) and it's coil spring so i was just wondering if i just need to move the spring mount cause it's in a different position to mine but other than that from what i can see it should bolt up after that,
    i just want to know if anyone knows if there is anything else i forgot?
    Thanks
    todd
    trailing arm mounts need to be moved.
    spring seats probably are not perfect either.
    its not a simple 'bolt in' job.
    Mt Macedon
    On Toymods a fella by the name of "twentyeight" put some form of F series (I think MX13) diff into his RA28. To his surprise, two of the trailing arms fitted, and two were close (from memory). So you may not have to chop everything off and start from scratch.
    Sign up (if you haven't already) and look at his members ride thread, it was in there recently-ish.
    Or just go out to your shed and see how things look with the F series sitting in the rear end of your car and work out what needs to be changed.
  1. So I Bought a 4AGE...
    By squish_m8 in forum Technical - Questions
    Last Post: 1st December 2009, 05:04 PM
  2. just bought an AE86 have some questions
    By subaer in forum Technical - Questions
    Last Post: 28th April 2009, 12:04 PM
  3. Anyone bought anything from JustJap?
    By Ksevn-T in forum General Topics (No Technical Questions)
    Last Post: 22nd February 2007, 08:42 PM
