Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 33
Thread: The AE86 Turdbox Build
  1. #11
    Jan 2015
    Dave
    Michigan
    South Lyon
    USA
    Looks good! Did you get the wiring harness/ECU and T-50 with the 4AGE.
    Dave W
  2. #12
    Junior Member Dorifutokingu's Avatar
    Sep 2017
    Arath
    TX
    Houston
    United States
    Indeed, includes the original ECU with the appropriate sensors and wiring harness. The guy threw in the stock oil cooler too which is a plus. It has a P/S pump which will also work with my setup. For the transmission I haven't decided on a T-50 or W-Series since the car will be seeing daily use. I have access to a T-50 for only 200 bucks and it functions well, I'm simply unsure of what will be more cost effective in the long run. Since the car was Zenki all the wiring is guaranteed to match up so I didn't bother with the underdash harness. I also have a zenki and kouki GTS cluster lying around my parts bin.
  3. #13
    May 2010
    Tyrone
    For $200 you can't really go wrong since it'll be a straight, no hassles, bolt in.
    If you plan on drifting/ tracking the car at some point, the w series would be a good improvement for reliability but if you're mainly planning on daily'ing, the 16v won't give the t50 much trouble.
    As a side note, depending on the direction you go with your w series setup, you may find you'll need the bell housing from a t50 anyways, so it'd be handy having those ready to go.
    Sent from my SM-G935F using Tapatalk
  4. #14
    Jun 2011
    bazz
    nsw
    sydney
    If you want to put the Gts engine in with no fus then get the under dash harness. The gts and sr5 are different. The rear harness is virtually the same but has the fuel pump wiring
  5. #15
    Jun 2011
    bazz
    nsw
    sydney
    Also to make things easy try to get the fuel tank. Fuel hardlines and the exhaust
  6. #16
    Sep 2017
    Arath
    TX
    Houston
    United States
    Ran back down to the west side of the city last night to recover the wiring harness. That hatch was GUTTED and it's either going to the crusher, sadly the owner is moving and can't take it with him, or if someone can grab it in the next couple hours it might be a good shell to save. I recovered the under-dash wiring, and the rear wiring as well. I had to do it rather hastily though since it got dark fast and it's not the area to be in at that time of night, I was approached by a few suspicious characters to say the least. I also saved the passenger side door card, the shift boot, and the antenna. The owner was cool and told me to simply grab what I needed before it was gone. In the case of the fuel hardlines, I don't mind bending my own, it's not a difficult task as I've done brake hardlines before as well. To my knowledge, some people are able to utilize the SR5's gas tank by simply dropping in the fuel pump bracket where the fuel pickup unit goes instead. This won't be too different since the neither the Zenki SR5 or GTS has baffling in the fuel tank. I've just acquired some new parts in the mail as well, I have my driver's side door handle and my clock bezel. I'm considering buying silvertop itbs, however I'd like to know if I need to buy a new adapter or if I can port this intake manifold for the Bigport 16V. Appreciate the help guys.
ID:	37707Click image for larger version.
  7. #17
    Jun 2011
    bazz
    nsw
    sydney
    Gts tank is baffled. But you can guy a cheap repro in the states. About $160 with shipping from amazon
  8. #18
    Jun 2011
    bazz
    nsw
    sydney
    Hardlines you can make a 8mm fuel line. For the pump and bracket there are a few options. You can use a inline one
  9. #19
    Sep 2017
    Arath
    TX
    Houston
    United States
  10. #20
    Sep 2017
    Arath
    TX
    Houston
    United States
    Wondering if anyone knows why my hazard lights may not function. My turn signals and brake lights work fine.
  1. Harry's AE86 Build
    By harryhalliday in forum AE86 Owners Forums
    Last Post: 5th November 2015, 01:44 AM
  2. ae86 build/resto
    By haveaparty in forum AE86 Owners Forums
    Last Post: 5th January 2015, 06:35 AM
  3. My AE86 build.
    By Dskew3 in forum AE86 Owners Forums
    Last Post: 5th March 2013, 11:43 PM
  4. MyRolla AE86 Build From NYC
    By MyRolla in forum AE86 Owners Forums
    Last Post: 21st March 2011, 01:11 PM
  5. the AE86 build off DEHNEY V'S 741 LOL
    By dehney in forum AE86 Owners Forums
    Last Post: 28th December 2010, 12:03 AM
