Need to make some room,
Big port head had surface and valve lap done about 2hrs work minus cams and bearing caps. 2 big port heads incomplete missing some valves, pretty much
Bare would suit the start of a turbo project, Big port Bare block std bore (needs re- bore), oil pump Used! some used pistons had about 2hrs on them before a spun bearing never re-used ACL 8018 press pins. Small port cams,
Can throw in other odds and ends if needed just want it All gone $50 the lot.
Pick up in Dandenong south.
Big port small port Adapter T6 Alloy nice item $100 can post.
Email please
