Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 40 of 65
Thread: bt 20v v's 3sge beams
  1. #31
    yes den bot you will have the same power as i did
  2. #32
    beams ohh yeah.
  3. #33
    Veteran slydar's Avatar
    Dimitri
    im not going to bother to read the whole thread but honestly.
    LOL.
    beams is a serious conversion, and serious motor, and fairly serious NA power.
    20v.. lol its hardly a conversion at all. and it just a 4age.
    youre talking a 10 years older engine, with 20% less capacity.. not really comparing apples. and a 20v has no chance of ever making the same power as a stock beams. it may pull the same figure on the dyno if you put $10 000 - $20 000 into it. but it will never accelerate the car as fast. capacity plus a much more sophisticated valve control system says never.
    78's
  4. #34
    well cams, compression, extractors and ecu are what i have planned for mine. may eventually get port, polish, valves cut, knife edged and lightened crank but that would be later down the line as i don't plan on changing the engine to anything else unless someone comes up with a decent (and not extremely priced) way to put a 2zzge in an ae86.
    i'm guessing it will cost closer to 5-6k than 8-10.
    Silver Top $400
    Rebuild + 0.5 mm headgasket $500 ish
    Water kit $400
    ECU + Tune $1500
    Cams $1500
    Clutch + FLy Wheel $1,000
    extractors $300
    I may have got the 4AGE fairly cheap but this is a rough guide of what i think it will cost. anyone who's done the conversion have a different opinion on what it will cost?
    No idea how much a BEAMS conversion would cost, but im assuming once its all in there it would be close to the 10k mark.
  5. #35
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    dude stick 16v or 20v if you must do something different, beams would be a fabrication nightmare, not to mention the extra weight
  6. #36
    Christian
    Burnside
    Hey mate what application will the car be for? If your talking about bt20v and beams 3s you must have quite abit of money to play around with If you want a hipo NA engine have you ever considered a 1UZ of a peripheral ported 13B conversion? Or if you want something cheap and simple why not a 4agte, a 150 rwkw 4agte will be 100x more reliable than a 150 rwkw na 20v
  7. #37
    User fantapants's Avatar
    Pat
    the weight isnt such a HUGE difference guys.
    i have pulled a lot of the engine, so all i have left in terms of accessories is the alternator. Manifold is ditched in favour of quads, and that thing is huge, so prob save a tiny bit there.
    prob save a bit on wiring too as there is fuckloads but seriously i recon there is prob only a couple kilos in it. I wieghed the 4age with clutch on and weighed the beams with no clutch or flywheel. cant remember the numbers - too drunk but the difference was only a little more than the wieght saved by going frp bonnet from memory.
    And its fairly easy to bring the weight back enough to not have the extra wieght swinging in front of the wheels. 4age sit relatively forward. The blocks are only about 1 - 2 cm different discounting the funky sump. The 4ag seems to mount directly between 2 and 3, but the beams mounts can be pushed back to an equivelant under 1 or between 1 and 2. (this is a bit of educated guestimation as i have only measured, not thrown the engine around the bay)
    But it is a serious bit of work
    06/07/2011
  8. #38
    Veteran driftke70's Avatar
    Ryan
    Buderim
    my standard dump and cat from the gen 3 weighed so much, the rest weighs no much more than a 4a.
    wheelfriends.wordpress.com
  9. #39
    gawler area.
    it wouldnt be that much of an night mare it would just take time to do and to do it right thats all its like with any conversion it takes time the main thing would be the sump i dont care about my gearbox tunnel as i would make a new one so i could use the 6speed box
    heaps of people have done it so it cant be that bad with the hole weight problem
  10. #40
    Ken
    Spearwood
    The comment about fibreglass bonnet, that doesn't make much sense, fibreglass bonnet with a 4AG then that's even lighter then?
    On paper depending what the difference on weight is, I'm still keen on finding this out for myself, but something even like 20kg makes a huge difference when sitting on the front of the car. And I'm willing to bet the BEAMS is quite a bit heavier then the 4AG, not too mention the gearbox and the diff you'll need the overall weight increase would be huge.
  1. Beams Vs BT 20v Vs BP 16v
    By PRIMRK in forum Technical - Questions
    Last Post: 20th February 2011, 04:10 AM
  2. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  3. Quads for beams ( 20v or 3sge)
    By DR86TY in forum Cars or Parts Wanted
    Last Post: 9th November 2010, 10:14 PM
  4. 20v ITB's on beams 3sge
    By dr1ft-pig in forum Technical - Questions
    Last Post: 3rd March 2008, 02:27 PM
  5. 3sge altezza BEAMS inlet manifold to suit 20v quads
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 1st July 2007, 10:16 PM
