Results 1 to 2 of 2
Thread: Removing bolt ideas - Rear diff
    Jul 2022
    Rob
    Norway
    Norway
    Norway
    Red face Removing bolt ideas - Rear diff
    Anyone got any ideas removing the follow bolt. Its rusted together
    Tried banging it out and heated blow torch.
    It does turn but welded itself together with inner rubber mentel.
    Had to cut the below one off but this one is hard to cut off
    Thanks!!
Name:	WhatsApp Image 2022-07-15 at 11.48.34.jpg
ID:	38276Click image for larger version.
Name:	WhatsApp Image 2022-07-15 at 11.48.34 (1).jpg
ID:	38275Click image for larger version.
    Clean it up with a wire brush first, soak it in wd40 and give that a go.
    Should that fail, heat it up and it will soon come out. Failing that, drill the head of the bolt off and tap it through with a chisel.
  1. Removing KE70 Front Quarter Panel - Sneaky Ninja Hidden Bolt.
    By HarlemSessions in forum Technical - Questions
    Last Post: 1st February 2012, 10:19 PM
  2. I have a rounded bolt - Timing belt tensioner - Any ideas?
    By maxhag in forum Technical - Questions
    Last Post: 11th April 2011, 08:18 PM
  3. removing rear wiper
    By khai2298 in forum Technical - Questions
    Last Post: 20th October 2009, 06:20 PM
  4. Removing rear axles?
    By Ksevn-T in forum Technical - Questions
    Last Post: 12th March 2009, 06:03 PM
  5. brake booster - removing, smaller one, other ideas
    By h1_roll4 in forum Technical - Articles
    Last Post: 11th January 2009, 10:58 PM
