Results 1 to 4 of 4
Thread: Interference and non interference.
    Luc
    Seaford
    Default Interference and non interference.
    Ok i've been told that i can use 4agze pistons in my 20v.
    but it'll make the motor an interferance motor.?
    if this is the case then what are the pros and cons of changing this?
    Scammer, DO NOT BUY FROM ME!
    cons of an interference engine is that if you snap a timing belt you can say good bye engine
    HAHAH I LOVE BOOST LOOSING!!
    Luc
    Seaford
    ok thanks pros??
    timing belt shouldn't be an issue Brand new HKS one going on it.
    Nathan
    Lilydale
    I wouldnt worry too much to be honest, Ive NEVER seen a timing belt like the 4age designed one break, Ive seen them stretch significanly when they get well over 200,000'ks old, but not break. as long as you are careful when initially setting cam timing, and timing belt tention, you will probably never have a problem.
    hope this helps
    -nath
  1. blacktop 20 valve 4age, Interference engine?
    By _sawyer_ in forum Technical - Questions
    Last Post: 12th February 2011, 11:16 AM
  2. tacho needle interference
    By pen15 in forum Technical - Questions
    Last Post: 26th June 2010, 08:48 PM
  3. Wheel alignment Qn - interference between LCA and rod ends
    By skit in forum Technical - Questions
    Last Post: 22nd March 2008, 11:20 PM
