Page 9 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 81 to 90 of 191
Thread: Greenmacs new KE10.. see page 9
  1. #81
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    vry good m8
  2. #82
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Fuckin epic efforts man... hats off 2 you...............
    Cant wait to see the final result... your doing a fantastic build
    BENT MECHANIX - Garage 20:
  3. #83
    Luc
    Seaford
    yeah first paintjob took ages. and wasn't happy.
    i've had such a shit fight with the engine bay i figured to ensure a quality finish i needed to start over.
  4. #84
    Luc
    Seaford
    for the moment i've had two deliveries today!
    this one will be the centre piece for my custom boot skin covering.
    and this will ensure my 9000rpm limiter won't cause engine failure!
  5. #85
    Luc
    Seaford
    some more progress shots..
    stripped back
    and some seam welding done
    in etch primer.
    first step of smoothing. metal mend fibreglass.
    hopefully get other side done tomorrow. then all i got left to strip is the back of the front panel and a little bit
    more of the firewall. YAY!!!
  6. #86
    love your work...
    truely epic.
  7. #87
    Luc
    Seaford
    update.
    my gasket kit arrived today... full of toyota goodness.!!
    did some more work on the bay smoothing.
    sat down and planned out my engine build..
    . ARP rod bolts
    . ARP main studs
    . ARP head studs
    . ARP flywheel bolts
    . Fully balanced bottom end with gze pistons
    . ACL race bearings
    . Supertech Valves 1mm oversize + valve springs + titanium retainers
    . Intake ported
    . Exhaust ported
    . need some more research into cams... may leave em stock.
    . TODA metal HG 0.8mm.
    . At this stage i believe i'll be using an EMS computer. have one sourced still trying to decide if its gonna be good enough.
    . 30mm trumpet inside custom plenum
    . Td-04/05 turbro on custom turbo manifold.
    . tomei crank cap ladders
    about as fas as i've gotten. but should be a tough engine.
  8. #88
    Luc
    Seaford
    thanks man much appreciated!!
  9. #89
    Luc
    Seaford
    some random side shots of the car.. all in primer.
    smoothing progress
    still more smoothing to do. more updates to come on that i've done more but nothing really photo worthy yet.
  10. #90
    Luc
    Seaford
    now since i've flaird my rear guard i need to flare my fronts. so today i got a crappy panel and gave it a go.
    turns out its quite easy!
    rear guard.
    front... need at least another 20mm
    marked the cuts out (note how they get smaller... this will help to retain the bodylines and provide a smooth transition.
    and cut
    bend em out a bit till you get your desired flare. tack weld then full weld.
    grind smooth.
    onece they are all done figreglass it and prime and prep it so its smooth for paint.
    only a test panel so i won't be doing the smoothing. but yeah thats todays progress.
  1. Outlaw Ke10 Build.
    By Jono.C in forum Other Toyotas
    Last Post: 2nd March 2012, 06:41 PM
  2. Nan's KE10
    By Jordain in forum Cars for Sale (Toyota Only)
    Last Post: 10th July 2011, 11:03 PM
  3. Ke10 build
    By Jordain in forum Other Toyotas
    Last Post: 9th August 2010, 07:46 PM
  4. WTB ke10
    By zookieboi in forum Cars or Parts Wanted
    Last Post: 4th July 2009, 08:58 AM
  5. DOES ANYONE HAVE A KE10 DIFF??
    By krumpet in forum Cars or Parts Wanted
    Last Post: 28th September 2008, 12:19 PM
