S13 front end is good, easy and cheap.
Falcons fit at the back, so do rear AE86, same with shocks.
Hey guys,
What suspension can be put into a RA60? just want something with good ride height and fairly stiff for cheap.
can ae86 suspension fit in one?
instead of going s13 does ae86 fronts fit?
i just want like shocks and king springs something second hand and cheap.
From all accounts the ra60 KPI is different to ae86 (which are around 8.5-9 deg) so the struts wouldn't work unless you want super sick neg.
The steering arms are different in the bolt spacing so you'd have to change them too.
The strut tubes are the same size though, so an ae86 coil over kit would fit, as would damper inserts.
King springs are $120 a pair brand new.
coilover the stock struts.
RT142 Estate.
AJPS.
looking for just springs and shocks as it is a daily
does anyone know what suspension would fit from other cars?
RA60 brakes are much bigger then ae86..
dude, dont be so ghetto.. new springs & fresh shocks.. so stiffer/lower springs and sw20 kyb's.
im in the same boat, except wanting to set up missile spec drifter.
was thinking some s13 coil overs off ebay, just gonna keep checking til some come up for cheap.
I asked pedders for a quote
they said $1269 fitted i laughed at the guy on the phone.
Get some coilovers from JDM garage. Should be able to do front setup for less then 1k
