can someone tell me the length of stock steering arms Vs Power steer arms?
im guessing their measured hole center to center?
the lock on that last pic is insane!
nut and thats with a rubbish ma61 rim
xt130 lca
Yep. Even I was imporessed by that pic. Still 1 or 2 days before I sort out my own steering.
The regular steerings arms are about 126mm from hole to hole, and the PS arms are about 113-115mm. The pivot point to pivot point length is a little different to that due to all the weird angles, and it's harder to measure.
soo... 2 lock spacers + power steering arms = win? ^_^
extra extra lock only looks good when u park...so why not =b
dose
Shortened (HEYMAN) knuckles, Tec-arts LCA, Cusco castor rods, rose-joint tie rod ends, no lock spacer or teeth cut. NRCA. Will extend the LCA soon and move it back to a normal RCA though, but for the time being it works fine.
Example :![]()
if u didnt spin in that pic u r god!
ke70 arms are shorter thatn ae86 std ones?? well they look that way, i could measure them but im lazy haha
AE86 THE BEST
Dam i just measured mine and their 133mm hole center to center!..![]()
