THIS CAR IS FOR TRACK USE ONLY!!!
Vehicle information: 1984 KE70 Slanty front 4K-C 5speed, on defect, impossible to get off as needs compliance plates done to cause it has the wrong plates and wont be an easy get off.. good engine, compression test comes up perfect. new exedy heavy duty sports tuff clutch and thrust bearing only done 500kms. baby blue in colour with on white door. rims on FRONT, stockers on REAR. has locker and cut springs. and brand new front left hand side wheel bearings and seal.
Condition: overall very good conditon.. no rust in rear guards rust repair done, a little bit of surface rust in spots. boot seal leaks, but thats an easy fix. choke is broken but just needs to be warmed up first then it runs fine. exhaust will need to be fixed as had broken from flange on exhaust manifold. a simple weld will do.
Price: $500 firm.
Contact: PM or 0401266163
