Results 1 to 9 of 9
Thread: w58 gearbox conversion, price etc
    Senior Member ae86ln's Avatar
    Lew
    Bolton Point
    Default w58 gearbox conversion, price etc
    how much do they usaully go for? and what else needs changing besides the bellhousing?
    thanks lew
    Ok
    Seamus
    Milton
    500-600. can vary a little more depending on whether you buy 'privately' or from an importer etc
    also need:
    -bellhousing
    -clutch spline changed from T50-W58 (should cost less than 100)
    -gearbox mount (stock, most gearboxes will come with one)
    -gearbox crossmember (custom)
    -shorten tailshaft and change front yoke, or get a whole new tailshaft made up (200-500). apparently you can just use the front-half of a certain car's tailshaft and match it up with the rear half of an ae86 shaft, but i don't know which one
    -speedo drive stuff
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I do believe that an RA40 front half tailshaft works with the AE86 rear half and a W5X box.
    todd
    i will be giving an ra28 front half a work out. from eye guestimates its a similar length to an 86jdm jobbie. but yeah, dont think its actually been confirmed although i hear like above that an ra40 is the closest.
    Lew
    Bolton Point
    does any of the standard sprinter clutch stuff need to changed
    Lawrence
    Wollongong
    5char
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    RA40 front half works.... using it on mine..
    BENT MECHANIX - Garage 20:
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    wat about with t series diff?
    Lawrence
    Wollongong
    Same as if you were using a T50 box and an AE86 front half.
    T18 or JDM AE86 rear half.
  1. W58 Gearbox conversion (Clutch problem)
    By Intense in forum Technical - Questions
    Last Post: 15th June 2012, 12:43 AM
  2. W58 gearbox
    By R&D Mechanical in forum Cars or Parts Wanted
    Last Post: 17th December 2010, 11:40 PM
  3. W58 gearbox
    By sumfancyname in forum Car Parts For Sale
    Last Post: 15th October 2010, 11:10 PM
  4. W58 Gearbox
    By tan18d in forum Car Parts For Sale
    Last Post: 22nd January 2008, 06:37 PM
