Results 1 to 10 of 10
Thread: Ae71 cluster into Ke70
    Member KePanelVan's Avatar
    Jun 2009
    Vic
    East Side
    Default Ae71 cluster into Ke70
    hey fella's just got an ae71 cluster with revs for my ke to replace the big fuel and temp gauge and i was wondering whats involved in putting it into a ke wiring wise?
    any links you guys know of for wiring diagrams?
    anyone done this that can shed some light?
    Senior Member Eddy's Avatar
    Edward
    pull out dash surrounds, pull out cluster itsself unplug wires and spedo cable
    put ke dash in and plug it up
    should all be the same plugs
    Quote Originally Posted by Nicko View Post
    Why don't you go drive a mates car around until you find a big tree?
    Site Supporter Javal's Avatar
    Josho
    Eddy's got the idea, it's a no-modification affair.
    The you might have some trouble removing the dash surround, they're a bit interesting to get in and out. Be careful or you'll crack it.
    Other than that it's plug and play. Remember to plug your speedo cable back in.
    Trev
    Queensland
    Redbank Plains
    I have found that the easiest way to remove the surround is to remove the wheel and drop the steering column.
    Josho
    Yeah i normally just take the steering column surround off, this gives you enough room, just.
    Jun 2009
    Vic
    East Side
    thanks for the quick reply fellas
    nah thats no biggie i've pulled the thing out a few times coz the old cluster had a shorting problem and kept blowing fuses for the petrol gauge...
    but i've plugged the new one in and the speed works being mechanical, the fuel works and isnt popping the fuse any more which is good but the issues im having are...
    - temp doesnt work
    - handbrake light stays on
    - dash lights dont come on
    - indicators both flash at the same time on cluster only
    - revs dont work
    - no high beem low beem light
    so yeah thats the problems so far, i've plugged everything in but was wondering if i needed to fiddle with the wiring to get everything going???
    update - found out that the ke70 cluster that has the big clock is a straight swap but mine is the one with the big fuel/temp gauge and has a small analoge clock on the top left side. Im assuming now that wires will need to be swapped in the plugs to get it all running right?
    Senior Member resol's Avatar
    steve
    vic
    they bolt in, with no mods. so if its not working either the dash cluster you got is dead, or something has gone wrong (i.e short in the board or interferrence).
    i have a good condtition working taco cluster if yours is dead. otherwise just have a look over to see if anything looks suss.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Jun 2009
    Vic
    East Side
    all good! i figured out that panel van are a bit diff and you have to swap some of the wires around to other plugs! im just going to copy my mates sedan so i should be right.
    If not ill shoot you a pm!
    cheers for all the help fella's
    Edward
    ahh its going into a pannel van, yes they have differnt placings of wires, hey when you work it out do you mind pming me with what you swapped around as i have a taco dash for mine and it didn't work
    Jun 2009
    Vic
    East Side
    lol yeah man its a lil trickie if your not good with that sort of thing which i ain't but try this link
    its all about swapping a ae71 cluster into a panel van and there is a write up link about half way down the first or second page!
  1. Replies: 9
    Last Post: 4th February 2013, 07:35 AM
  2. Smallport AE71 Overheating issues/cluster issue, well I think so
    By pauliee in forum Technical - Questions
    Last Post: 13th August 2012, 10:26 PM
  3. KE70/AE71 tacho cluster.
    By Ben 1 in forum Car Parts For Sale
    Last Post: 3rd January 2011, 05:18 PM
  4. AE71 CSX Tacho instrument cluster
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 17th May 2009, 10:24 AM
  5. ae71 panel van dash cluster
    By Clinton in forum Car Parts For Sale
    Last Post: 3rd October 2008, 05:36 PM
