View Poll Results: should i murder my door cards and put 6" speakers in ...
Voters
147. You may not vote on this poll
  • Yes, chop them up!
    34 23.13%
  • No, keep them clean!
    113 76.87%
Page 7 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 61 to 70 of 418
Thread: Faceplants 86 build
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    yeah i fixed that on my jap cluster today. 2 pins need to be swapped on the white plug. the one for handbrake and the other is brake fail. i think its pins 4 and 5. theyre both red+black (if i remember correctly). just swap them around and your cluster will function as normal.
    Jul 2009
    Daniel
    Morisset
    alright cool ... ill do that after i get my cluster im actually going to use. it looks so much better than the standard jdm ones.
    Jul 2009
    Daniel
    Morisset
    clutch fan and radiator are now installed, will be finishing pipes for cooling tomorrow.
    and if i get time ill install the oil cooler.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    FYI the bit which is lighting up is the catalytic converter temperature warning light.
    But as said, swap the hand brake light pins into the correct position then the correct light will illuminate.
    Jul 2009
    Daniel
    Morisset
    why would anyone think that a catalytic converter needs a temp light? it sounds a lil odd to me... ill wait before i swap the pins over untill i get my good dash cluster... which im still waiting on to turn up in the mail ... but when it arrives if i have the same problem ill swap the pins.
    Jul 2009
    Daniel
    Morisset
    So i got my nice new camber top top plates made up on Friday, 5mm stainless steel is what i chose to have them made out of and i had them water cut to the same spec's as the Cusco AE86 tops. they look sweet, and the only reason i made the tops was that i had RA60 tops before and the center fitted to the AE86 ones so i just made the top plates and it turned out cheaper than buying another set of tops. any way heres some pics.
ID:	6150   Click image for larger version.
ID:	6151   Click image for larger version.
    Dan/Rio
    Randwick
    made by your brother? they look the goods mate.
    people with old xA2x celicas would love to be able to get custom stuff like that made for them. should let your brother know and maybe he could make some dorrahs on the side
    Jul 2009
    Daniel
    Morisset
    my bro didnt make them sadly ... but he did supply the stainless steel for me ... they were "off cuts" ... which both just happened to be the exact same size and perfect for me to use ...
    but i took the steel to a machining shop in Wyong called... Easy Motors. i paid them to cut them out as they have a water cutter and it would give me a better finish than anything my bro could do.
    Jul 2009
    Daniel
    Morisset
    ok so i spent all day working on my car today ... i now have the camber tops bolted in and set ... they took a decent amount of camber off my wheels so they are a lil straighter now ... and if i like i can get a fuck load more than what i already had ...
    i also finally hung my exhaust it took a while but its in now and it has a cat in it. which i welded in myself at work when we had nothing to do. the cat dose hit on something atm but its in place so until i am able to start it up and see if it vibrates on anything it will stay as is ...
    i now have working window washers to i first tested the motor with a 9v battery and found that i had blocked pipes so after cleaning them and it tested ok with low pressure i hooked up the spare 12V battery i had laying around and they worked sweet but i might need to adjust the aim a lil bit, and i did notice that the wipers don't come on when you hold down the spray button ... is that normal i know on newer cars they come on when you spray the window but i wasn't sure about the AE86.
    so the things i need to get done still is get the oil cooler on , finish the radiator plumbing, have an auto elec extend my loom, and work out why i have no headlights and why my brake lights come on as soon as i connect power to the body looms.
    anyway heres some pic's of my work i did today.
    note: the pic of my drivers side wheel is how it was without my camber tops and the pic of the passenger side is how it is with the camber tops.
ID:	6163   Click image for larger version.
ID:	6164   Click image for larger version.
ID:	6165   Click image for larger version.
ID:	6166   Click image for larger version.
ID:	6168   Click image for larger version.
ID:	6169   Click image for larger version.
ID:	6170   Click image for larger version.
ID:	6171   Click image for larger version.
    Jul 2009
    Daniel
    Morisset
    just worked out ive spent over 5k on this ... but then i minus the parts ive sold from this and im back to under 4k ...
    good thing i dont have to pay for labor or id be up in the 6-7k mark i think .
    ahh the good things about being an apprentice mechanic.
  1. 86/4AGTE Local Build Help [Birkdale/BNE]
    By thermos33 in forum Brisbane & QLD Events and Discussion
    Last Post: 23rd January 2012, 07:11 PM
  2. Roco,s 1uz 86 drift slut build
    By roco in forum AE86 Owners Forums
    Last Post: 28th January 2010, 08:26 PM
  3. Sick of building your 86 outside? Why not build it on ur desk??
    By DRFTAE86 in forum General Topics (No Technical Questions)
    Last Post: 16th January 2008, 02:23 AM
Tags for this Thread
