View Poll Results: should i murder my door cards and put 6" speakers in ...
Voters
147. You may not vote on this poll
  • Yes, chop them up!
    34 23.13%
  • No, keep them clean!
    113 76.87%
Page 16 of 42 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
Results 151 to 160 of 418
Thread: Faceplants 86 build
  1. #151
    Jul 2009
    Daniel
    Morisset
    battery set up is in with a quick install, i just need to tidy it up a lil more and make a better earth. heres a few pic's of it installed follow the big thick red wire...
    on closer inspection the rear tower brace i got from skit isnt the same as the one my car had installed previously so im still going to have to fill the holes in the towers
ID:	7279   Click image for larger version.
ID:	7280   Click image for larger version.
  2. #152
    Jul 2009
    Daniel
    Morisset
    had a bit of a play around under the bonnet today and i mounted my coil pack extended the wires for the coil pack, cleaned out the car cleaned out the garage, connected all my positive wires under the bonnet to the power cable, apart from the starter motor.
    on the starter motor i have a thick black wire coming off it should that be connected to the positive? then i have a little wire next to it dose that go to the ignition? any pics would be great help.
    now i got this loom ... WTF is it and where dose it go... do i need it?
  3. #153
    Rob
    Moorabbin
    Never seen that plug before? (but not really familiar with smallport) It should be pretty obvious what it plugs into if it's meant to be there!
    On the starter, the smaller wire goes to STA and the larger one goes to +... if you had the smaller one going to ign then your starter would be running whenever the motor is turned on!
    Looks like fun
  4. #154
    Jul 2009
    Daniel
    Morisset
    lol ok, so i run a wire from the STA on the ECU to that wire?
  5. #155
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Yeah those wires are from something else, they're not AE86 or 4AGE related.
  6. #156
    Jul 2009
    Daniel
    Morisset
    yea i thought so i couldnt find anything for it to plug into, i was thinking it was from an auto G/Box from a corolla if the SX corolla ever had a Auto box with the 4A-GE but i dontthink it did.
  7. #157
    Jul 2009
    Daniel
    Morisset
    been stripping the factory window tint the last few days ... its a bit of a bitch. but im down to the last quater glass. ive just been using a razor blade and some metho to get the glue off after i peal it. it looks really weird now because the tint was so light you didnt really notice it but now its gone you can really see its missing.
  8. #158
    Jul 2009
    Daniel
    Morisset
    i got bored so i quickly wired my old CD player into the car. i threw a box with some 6x9's in it on the back seat and re wired the original fronts into the mix and its not bad ... it will be alot better when i work out what im really gonna do for sound in this.
  9. #159
    Leigh
    Penshurst
    looking good hey!!
    nice build thread and thanks for the surge plug :-)
    it looks well hidden up under the car
    Leigh
  10. #160
    Jul 2009
    Daniel
    Morisset
    yea its up there alright ... i dont think its in danger of getting hit from anything ether as the diff is in front of it also.
  1. 86/4AGTE Local Build Help [Birkdale/BNE]
    By thermos33 in forum Brisbane & QLD Events and Discussion
    Last Post: 23rd January 2012, 07:11 PM
  2. Roco,s 1uz 86 drift slut build
    By roco in forum AE86 Owners Forums
    Last Post: 28th January 2010, 08:26 PM
  3. Sick of building your 86 outside? Why not build it on ur desk??
    By DRFTAE86 in forum General Topics (No Technical Questions)
    Last Post: 16th January 2008, 02:23 AM
Tags for this Thread
