ok so today i fitted the seats as pictured above and i also wired in the air fuel ratio gauge.
Yes, chop them up!
No, keep them clean!
picked this up today
and i got some auto meter gauges on friday ... Air fuel ratio and a mechanical oil pressure
good ol shane aye
yep hes going a half cage so 2 seater rego for him
he had a half cage in there before
yea hes going half cage and bucket seats engineered in. i havent seen him for a while so im not up to date with what hes doing ... is he still going back to panda?
yeh as far as i know
i got an adjustable panhard rod coming for this. just waiting for it to arrive.
today i wired my fog lights to only come on when the parking lights are on so now they work on all the light settings and turn off when the lights are off ... but i still have the toggle switch to turn them on and off.
i also put my watanabes back on at the back ... im going to try and get it blue slipped with them on... i cant see why they would fail ... they are only 2" larger in diameter and 1" wider than standard rims. + they only have a 195/50R15 on them which has the same rolling diameter as the stock 165/70R13.
and i took some random photos the other day.
my whiteline adjustable panhard rod arrived today ... and i had it fitted about 15min latter.
i also have a panel beater coming around to check out the rust i have behind my rear bar ... he is gonna quote me on the repair and hopefully take it to start work![]()
OK so since last update, i have installed a good head deck & Sub, put in new rocker cover gaskets, new O ring on the dipstick, resealed the water pump, new timing belt, i have a head gasket ready for the engine but i first have to work out if it is blown or not ... i also re greased my front wheel bearings.
the panel beater never got around to giving me a quote the bastard. so i put my rear bar back on and decided to go for blue slip again.
i called the blue slip guy and he said my wheels will pass aslong as they are sitting in the guards this time.
so blue slip is booked in for 22-7-10. i should pass this time and ill finally get my AE86 on the road.
Also tomorrow i am going to the RTA and im ordering my Number plates. After i have paid for them and they are put into my name i will announce what they will read.
