View Poll Results: should i murder my door cards and put 6" speakers in ...
Voters
147. You may not vote on this poll
  • Yes, chop them up!
    34 23.13%
  • No, keep them clean!
    113 76.87%
Page 40 of 42 FirstFirst ... 30 31 32 33 34 35 36 37 38 39 40 41 42 LastLast
Results 391 to 400 of 418
Thread: Faceplants 86 build
  1. #391
    Jul 2009
    Daniel
    Morisset
    Haha cheers mate,
    ive got the block and head separated on the 20V, the bores look good in it, still has cross hatching, ive already been cleaning the block, tomorrow ill try and pull the pistons out so i can clean them up, then ill start striping the head down so i can get to work on it, gonna work the valves maybe throw some upgraded springs in there. ill probably shave the head a little bit and do a little port & polish work.
  2. #392
    Jul 2009
    Daniel
    Morisset
    been doing some work to my 20V im building, so far i have polished the exhaust side of the head, flowed & lapped the valves, cleaned alot of stuff and painted stuff too.
    in the way of mods for this engine i currently only have some adjustable cam gears but ill be getting some H beam rods and some better valve springs and cams.
    heres some pic's.
ID:	21367Click image for larger version.
ID:	21368Click image for larger version.
ID:	21369Click image for larger version.
ID:	21370Click image for larger version.
  3. #393
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    engine is looking good bro
  4. #394
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Are you doing any serious porting or just a general cleanup and de-dagging? Just that it's very easy to lose a fair amount of air flow porting heads if you're not exactly sure what you're doing. Not having a go or doubting your abilities, you've done a really nice job so far.
  5. #395
    Jul 2009
    Daniel
    Morisset
    im not going crazy on it, the head is already a very good design.
    all i have done is sand the exhaust side smooth, just with sand paper on a drill starting corse and then moving on to the fine stuff. and for the intake side all i have done is clean off the casting dags.
    you can see the ports are polished up compared to the rest of the head.
  6. #396
    Jul 2009
    Daniel
    Morisset
    16V is broken. cylinders 2 & 3 have been lost. hopefully its just the head gasket blown out between the two cylinders.
    ive also ordered some H beam rods for my 20V.
  7. #397
    Jul 2009
    Daniel
    Morisset
    HUGE Win today.
    ripped my head off and its exactly as i expected. the H/G blew out between the 2 cylinders.
    so ill hand machine the block with sand paper and ill take my head into my work and give it a quick skim over with our head cutter.
  8. #398
    Jul 2009
    Daniel
    Morisset
    20V is almost ready to put together fully. the head is currently being fitted with toda valve springs. then ill give it a light shave and bolt it on.
    i also had my AE86 on the dyno the other day. after fixing the head gasket the motor ran alot better. and the light skim i did to the head boosted power a decent amount.
    heres the video,
    i also have sent my diff center away to have the LSD rebuilt and another set of 4.3:1 gears put in as my last ones got ruined... again.
    so with a fresh set from japan i should have that back in before the weekend. im currently driving on a welded 3.9:1 diff center which is fun but i miss the 4.3:1 gears.
  9. #399
    Veteran timbo's Avatar
    Tim?
    Wild West
    Nice result!
  10. #400
    Jul 2009
    Daniel
    Morisset
    went out to eastern creek for the one day power play. i finally got to get some good drifts going. ill post up some pic's once the pro photos are uploaded.
  1. 86/4AGTE Local Build Help [Birkdale/BNE]
    By thermos33 in forum Brisbane & QLD Events and Discussion
    Last Post: 23rd January 2012, 07:11 PM
  2. Roco,s 1uz 86 drift slut build
    By roco in forum AE86 Owners Forums
    Last Post: 28th January 2010, 08:26 PM
  3. Sick of building your 86 outside? Why not build it on ur desk??
    By DRFTAE86 in forum General Topics (No Technical Questions)
    Last Post: 16th January 2008, 02:23 AM
Tags for this Thread
