i found it nevermind, but whats happening to your build??
whats the link to the ebay gear
im just going to run stage 1, I want to crack 200 on a standard bt bottom end, when I break it then I'll spend the $$$
lol it can be done rio, have faith my friend.
nah rio if i go the big motor, ill have to run race fuel, or its a waste, and it would make the whole thing that expensive to run, and use, it wouldn't be worth it, it would cost atleast $200 in fuel for say 6 20 min sessions if im lucky.
This way, i set it up how it was, it will atleast make 130kw atw, it did before, and im happy with that, and i can run 98.
there is more to life than a nuts 20v i cant afford to run
well people have been able to make 200hp 4ages and reliable aswell. using a stock bottom end scares me.
one day ill take some pictures of my broken blacktop bottom end i ripped outta my car. MASSIVE holes in both sides of the block. bastard still ran though
the conrods tend to stretch when under major heat. i would atleast just chuck some cheap aftermarket rods or gze rods in. that or just use a silvertop bottom end which are piss cheap and just chuck the bt pistons in it.
what about those spool rods any good?
nope, its all ready to go as it sits, just need, rings, bearings, headgasket, and timing belt.
Rewire the ecu to fire the coils with out the cdi.
make up a fuel system,
power it up and turn key.
so for 1-1200 i can atleast move the car under its own power.
So went to a rave last night with my ex(one i just broke up with), Klutch and 2 other friends. ex od'd on pure mdma, ended up getting a ambo to hospital at 130am ish, was waiting in waiting room to 5am. Then went to hers, slept a few hours and we both woke up and hooked up. Then spent the rest of the day both taking turns in crying and making out etc. Shit sucked.
"New evidence found: Hoon driver linked to 9/11."
