Results 1 to 5 of 5
Thread: 20v cam timing
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default 20v cam timing
    ok story goes like so....
    On my 20v I removed the timing belt quite some time ago, without even thinking about the timing etc, since then I have manually spun the crank a few times without the belt attached so the cams have not rotated with the crank...
    Now I have no idea where the cams are meant to sit while the crank is at TDC? The only thing I can add upon this is the timing markers on the cam pulleys are at roughly 1 o-clock & 11 o-clock (inlet/exhaust)\
    Where should they be?
    Cam they be spun without moving the crank? or will this cause damage?
    Any help appreciated...
    Niz
    BENT MECHANIX - Garage 20:
    Jun 2009
    Grant
    California
    San Jose
    USA
    Do you have a shop manual? Go find one if you don't, they're on the internets.
    AT TDC (not BTDC),
    Each cam pulley has 2 marks. When at TDC, the intake cam should have one mark matching the mark on the top of the cam cover, and one mark pointing at the exhaust cam.
    The exhaust cam should have one mark pointing right at the mark on the intake cam, and one mark pointing at the notch on the top of the cam cover. Both should match up pefectly, the crank should be at TDC. Then you try to put the timing belt on as best you can.
    Just know that you shouldn't turn the crank separately from the cams in the future....on interference motors that's a no-no.
    Niz
    South~Slide Briz
    TDC that's it, I wasn't sure when I was typing the first post. (mental block)
    Cheers for clearing that up, makes sense now I think, I can see the the marks on the pulleys, the inlet actually looks as though it has 3 for some reason though?
    I will have to wait until I get my cam cover back so I can check against the marks on it before going any further....
    no doubt something else will stump me... until then,
    cheers for the help
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    On this site there is Blacktop Manual.
    Its what I used when assembling GZE block and Silvertop Head. Goto Engine Mechanical - Timing belt installation, ignore the tensioner if you have ST because the BT is hydraulic. It shows you the crank pulley mark and cam pulley mark allignment.
    Niz
    South~Slide Briz
    cheers Oly..
  1. Cam timing!
    By Low Style in forum Technical - Questions
    Last Post: 22nd July 2012, 06:41 PM
  2. HKS timing belt and adjustable cam gears 20v
    By ONCHRG in forum Cars or Parts Wanted
    Last Post: 30th October 2010, 09:12 PM
  3. 20v top cam/timing belt cover
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 25th August 2009, 03:41 PM
  4. WTB: 20v cam cover and timing belt cover
    By grantobius in forum Cars or Parts Wanted
    Last Post: 25th May 2009, 08:23 AM
  5. 20v cam timing
    By b1gb3n in forum Technical - Questions
    Last Post: 13th April 2006, 03:35 PM
