I just got some wheels that clear my wilwoods sorted thanks to Mungi Mods.
The way the centres are cast they miss the brakes at the spoke area. Way to go 1983.
pretty much everything clears wilwoods
your brakes are worth more then the whole car haha
This thread is about people with 4 piston brakes. In particular wheels that clear them. If you have zero contribution to make there is no need to post.
Specs -
rx7 fc calipers
ae86 strut
mini cooper 294mm rotor
Spacer - stupidly wide spacer to fit any wheel. (ive tried meshies, ssr's, etc etc.
Wheels - 15x7+30 watanabes
Caliper protrusion - about 30-40mm at a guess
overall: not happy
anyone swap for ajps setup?
wilwood big brakes
ae86 struts
280mm rotors
wheels 15x7(+10ish i think???) ssr reverse mesh
no spacers needed
theres 12mm clearence between rim and caliper so heaps of room
Caliper protrusion - about 5mm
min size wheels - 15s
Simmons V4s have 3mm of caliper clearance,
Im using MPV discs, RX7 calipers and a caliper bridge, custom adaptor
Thats a 20mm spacer, so around 22-23mm protruding from the hub face.
ah very nice setup frak! i've got starsharks and am yet to see if they clea,r got some 15mm bolt on spacers sitting here just in case though
RX7 FD 4 piston caliper
AE86 struts AJPS adapter
262mm EG6 Civic rotor
12mm slip on spacer (note hub-centric ring machined in spacer)
Longer wheel studs
All SSR Mesh type
15x7.0 +3
15x8.5-21
15x9.0 -2
As you can see clearance with civic rotor diameter I could opt for most 14" wheels if desired![]()
